Question about Gateway 3347-02-10NA Wireless Router
How do i secure my wireless router? ive tried putting the ip address into the search bar but it says it cant connect.
    President:
  • 1,768 Answers
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
10. uninstall the the router > with the CD provided by the manufacturer and then reinstall and follow the previous steps.
11. check with the ISP ( internet service provider) to see if you have connectivity.
Posted on Mar 16, 2011
I cant get continous interenet from my linksys router, it would connect, then be intermittent.. the next page id go to would say cant connect.. or something like that.. id refresh like 20 times and finally...
In my experience this uaully means the router is toast and its time to buy a new one, but I will give you a few ideas to try before you junk your router.
First I would attempt resetting this router to factory defaults by pressing holding the small button located on the back of the router, you can access the button with a small pin of sort where the button is very small. You will have to reconfigure your router once this is done, but it should work right away unless you are using DSL, you will need to put your ISP account info in the router.
You can access your router by running a ipconfig command in the command prompt.
To access your command prompt in Windows 7/Vista just go to the search bar and type cmd and press enter.
To access your command prompt in windows xp go Start>All Programs>Accessories>Command Prompt.
Once you have the box up type ipconfig, you should get similar to these results:
Connection-specific DNS Suffix . : workgroup
IP Address. . . . . . . . . . . . : 192.168.1.25
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : Your Routers IP
You can see where I have bolded Your Routers IP, that line should be your routers IP address that you type in your internet browsers address bar.
This will bring up your routers configuration page where you can do your configurations.
I hope this helps, thanks for using Fixya!
Jul 22, 2010 | Linksys (WRT54GC) Router
Need to secure my connection
go online to access your router and use your IP address to do so put it in your main search bar at the top of the explorer window, when ya do you can set up a secure connection from with in it ok find your IP put in you search bar hit enter and should bring it up !
the fixist good luck and have a nice day
Jul 01, 2010 | Belkin (F5D7230-4) Router (587009)
I am trying to add a new mac ip address to my wireless router i started with 1 pc then brought a laptop and a wireless d-link router they work fine i just brought home another pc it has a card put through...
Please follow the steps mentioned below on the Computer where the internet connection is working normally and check if the issue is resolved.
  • Please type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
  • Please Use "Admin" as the user name and leave the password blank when the login screen appears.
  • Please click on Wireless, enter the Wireless SSID name (name for the Network) and under Security, select the Security type and type the Security Key.
  • Save the settings and try to connect to Wireless on the Computer having the issue.
  • It will ask for the Security Key, enter the Security Key provided during the Wireless setup.
This should resolve the issue.
If the issue is not resolved, reset the Router to factory settings and then try connecting.
Please try to locate the Reset button near the Ethernet ports and press for 10 seconds.
Good Luck!!!!
Please let me know if you require further assistance.
Thank you for contacting.
Jun 23, 2010 | D-Link SWT DSL-504T ADSL MODEM with 4...
I would like to set a secure wireless network. What do I need to do to reconfigure my router?
click start click run, or type in the search box if using vista, type CMD and press enter
type ipconfig
make note of the default ip address and type that into your web browser in the address bar
might ask for username and password try admin for both , as you havent mentioned what your router is or who you getting internet from
look for wireless settings and in there you should find security
this will then allow you to set a wireless key
choose WPA rather than WEP as its more secure
enable it, save settings and restart the router
search for wireless connections on your laptop and enter the security key that is on the router and you should now have a wireless connection
Oct 30, 2009 | Microsoft MN-700 Wireless Router
Cant get to routers login screen
click on start click on run (if XP) or search (if vista) type "cmd" and hit enter u'll get a black window and in that type "ipconfig" and hit enter u'll get a list of numbers under "ethernet adapter local area connection" if its a wired connection or "wireless adapter local area connection" look for "deafault gateway" that's ur router's IP address, just type it in the address bar and bingo u'll be in ur router page.
May 14, 2009 | NetGear DG834G Router
I cant change my NAT
Take a note of the IP Address Of the Xbox
Connect Router - Computer ( Wired )
Open RSP By typing 192.168.2.1 on the Address Bar of internet Explorer
On the Left Side Click Firewall
Leave the Password blank and click Submit
Disabled it and click Apply Changes
On the Left side Click DMZ
Enable it and Give the IP Address of the XboX in it
Click Apply Changes
Restart the Router
And test the Connection
Let me know if it works
Apr 21, 2009 | Belkin (F5D8231-4) Wireless Router...
How do I secure my DLink-524 wireless
In securint your wireless security try accessing the configuration page of the router. go the the window where you created your wireless netowrk connection.
On that Wireless window choose WEP for security.
By defaut WEP Encryption is 64bit.
Under Key1 erase what's on the box and type in the password for your wirelss network. It should be exactly 10 characters, You could use 0 to 9 or A to F then click on Apply >next.
Try Accessing your wireless networ.
Nov 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Un secured linksys router
first need to reset your router push the reset button at the back of the router for for 10 sec. then open internet explorer type 192.1681.1. enter type password admin enter ,..configure again your router enter the IP address. , Subnet mask , and DNS put the setting Static IP ,next click mac address clone and click "clone your pc mac" then click wireless at wireless network mode put it mix, at wireless channel put to the highest ghz. then after that check your line by trying to conect to the other pc using your UTP cable if it is working connect it again to your laptop
Jun 23, 2008 | Linksys Wireless-G WRT54G Router
CONNECTION TO ROUTER WGR614 V6
Do u have any wireless security set on ur router ?
do a IP config/all in MS Dos window. then, note down the default gateways IP address. Then, open a browser and put the IP in the address bar. this will open ur Router's Config page.
Go under security to see if u have WEP or WAP turned on.
Apr 17, 2008 | NetGear WGR614 Wireless Router
Network Key
Connect your PC to your router via a ethernet able, fro, the LAN ports to the machine. Reboot the router, wait 2 min, and boot up your machine.
Go to STARTt>RUN>type in CMD. Press Enter. In the black bix that opens, type ICONIFG.
Look for your IP Address. It should be 192.168.x.xxx. (X can be any number up to 254.) Subnet should be 255.255.255.0. Gateway IP should be 192.168.x.1.
If your IP address is 169.xxx.xxx.xxx, you are not connecting to your router. Put the Gateway Ip into your IE address bar. That should open a window that asks for your username and password. Put those in and go to the Security area, or tab. It should show your key there, and what security mode it is using, such as WEP, WPA, etc. There you can see what it is, or change it. Let everyone else using the router know about the change.
Jan 13, 2008 | Linksys Wireless-G WRT54G Router
Gateway 3347-02-10NA Wireless Router Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
