Question about Microwave Ovens
The touchpad dont work. gives an error message SE
  • 4,323 Answers
Hi
I believe your is a Samsung Microwave...SE error means shorted keypad and to solve this issue the keypad/touchpad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 16, 2011
What does this mean on my Samsung smh9151 microwave oven? -SE-
The SE error indicates a short was detected at the key pad. This could be a problem with the wiring (dirt at a connection) or a bad circuit board. If your microwave is under warranty, contact Samsung.
Since microwaves have high voltage, you may not want to try to fix this yourself. If you do, make sure to be careful. Some have fixed the error after unplugging the microwave. Then disassemble the microwave keypad area. Disconnect the various wires and clean all of the contacts. (Do one wire harness at a time so that you replace them in the right place.) Reassemble and plug in the microwave. Test if the SE error returns. If the error remains, then the control board needs to be replaced. To get the entire keypad and control board, seehttp://www.repairclinic.com/Shop-For-Parts/a6b160i468/Samsung-Microwave-Touchpad-And-Control-Panel-Parts . The board alone is here: http://www.repairclinic.com/Shop-For-Parts/a6b160i324/Samsung-Microwave-Control-Board-Parts .
I hope this helps.
Jan 16, 2016 | Samsung Microwave Ovens
Smh7178ste
Bad touchpad. Part# DE34-00205C for just the touchpad or DE94-01120D for the control assembly (easier to replace but more expensive)
Aug 09, 2014 | Microwave Ovens
Microwave started beeping with nothing in it now it says SE or 5E
These issues are usally due to a defective touchpad or control board. Troubleshooting would require disconnecting the touchpad ribbon cable from the control board to see if that made the problem go away.
Jul 17, 2014 | Microwave Ovens
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Kenmore microwave displaying SE error message. How do I fix it?
That error indicates a bad keypad. You will have to replace the keypad/control console assembly.
Apr 22, 2014 | Kenmore Microwave Ovens
My GE microwave JVM1740DM1WW no longer is responsive to the keypad. Lights, fan, power etc. don't turn on. Just beeps and gives a "disply shortage" error message along with a "might need...
there is no easy fix to this units current problem it will need to be looked at by a service tech as the fault is an internal circuit shortout and needs to have the faulty circuit found and then replaced using expensive testing units
sorry
merry christmas
Dec 21, 2010 | GE Profile Spacemaker Over-the-Range...
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
Error message SE
Hello :
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect .
I hope this will help you .
please rate !
Mar 29, 2010 | Frigidaire Microwave Ovens
The touchpad on my microwave has quit working.
possibly a stuck button which would mean a replacement pad, do the buttons bleep when you push them do some work and others dont its quite common normally its the start button or the cancel which goes(due to constant pushing) and it causes the error alternatively its a possible logic board fault which is far more expensive to replace!
Nov 12, 2008 | Microwave Ovens
Microwave Ovens Logo
260 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
