Question about Kenmore Dryers
My dryer will not come on and the breaker is not tripped
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
How to replace a fuse in a hotpoint
Check the circuit breaker for the plug the dryer uses. Open your house power panel and locate the breaker for the dryer. It will be 2 breakers connected together by a metal pin so when one trips it will trip the other. This shuts off 240 volts. Sometimes only one breaker will trip without tripping the other one. This leaves the dryer with 115 volts to work the rest of the machine but won't power the heating element. Replacing the breaker will fix the dryer.
Nov 17, 2014 | Hotpoint Dryers
This is an update to my previous problem with my electric Kenmore Dryer Model #88042700. The dryer appeared to have no power. I had checked the breakers and thought the one for the dryer was on. But it...
There is a reason it's tripping..First I would have the dryer cleaned out it sound like the unit is full of lint and is holding heat also bad ventilation in dryer exhaused. If it's tripping it's electrical
hydeparkappliancerepair.com
Sep 08, 2013 | Kenmore Dryers
SHORTED THE DRYER BY TOUCHING WIRE TO BODY, THERES POWER INSIDE THE DRYER(LIGHT ON), BUT NOTHING HAPPENS WHEN SWITCH IS ON, CONTINUITYIS GOOD ON START SWITCH, WHERE DO I GO NOW
Power to the dryer is 220 volts, with half of the total voltage supplied by each of two breakers. The breakers are combined into one larger breaker, but each side of the breaker connects to a different buss bar in the breaker box. What it sounds like is that one half of your breaker is tripped, and the remedy is to trip the double breaker in order to reset the half that is tripped. If tripping the breaker off and back on does not restore the operation of the dryer, trip the breaker back off, unplug the dryer, and check for any burned wires at the terminal strip where the cord connects to the dryer. Replace any defective or burned parts.
Best regards, --W/D--
Mar 06, 2011 | GE DBXR463EBWW Electric Dryer
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
220 dryer CH Breaker only trips partially and dryer does not reach full heat. Is breaker problem or dryer?
I would say that the problem is in the dryer, but only tripping partially is not exactly right either. It is easy and relatiuvely less expensive to replace the breaker . $40 .. if you replace the breaker and still get it tripping after a few minutes of opperating the dryer , then it is time to call a service tech for the dryer.
IF the breaker trips immediately when connecting the dryer, then unplug the dryer and try again, to see if there is a wiring problem in the line before the dryer.
Jun 05, 2010 | Cutler Hammer Ch220gf Circuit Breaker
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Dryer trips circuit breaker smell almost like something burning coming from dryer
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Jul 30, 2009 | GE DVLR223 Dryers
Breaker was inadvertantly tripped by person which shut dryer off when reset breaker dryer wont work
You have to test the voltage to verify that the breaker did reset. Unplug the dryer, and verify that you have 240 volts at the receptacle
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Dryers Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
