Question about HEALTHRIDER R60 SoftStrider Treadmill
Incline motor stays on going down, and will not respond to the controls. healthrider R 60
  • 84 Answers
Could be bad incline sensor or c/board is going bad. one more try bipassing the board with power to the incline motor fully powered 18volt batt will or higher will move the motorby flipping thr wires on the bat the incline should go up and down. if working ok then check board
Posted on Mar 18, 2011
My HEALTHRIDER H95T treadmill is stuck in the fully elevated (level 12) angle on the platform and will not move
The incline motor is jammed due to a faulty incline sensor or incline motor assy. This is somewhat hazardous if you do not know what you are doing to remove the incline motor. Sometimes you can repair it most of the time you replace the incline motor assy. Must be calibrated upon completion.
Feb 22, 2015 | HEALTHRIDER H95T Treadmill
Healthrider 15.5 won't run,motor makes alittle grunt,turns alittle but won't run,incline motor works
hi Geoff,
if it is contain belts please check.and try to move running belt it must run freely.sometimes it must stuck because of long idle time.
in electronic circuit the large smoothing capacitors can be damage because of long idling time too.
let us know the status,
regards.
nuwan
Jan 10, 2014 | Exercise & Fitness
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
The incline on my HEALTHRIDER treadmill wont decrease. Help please!
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
Jun 29, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
My son folded my healthrider s300i while it was in an incline position now the incline doesnt work is there a reset to fix this?
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Jun 23, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
When starting my treadmill the incline just starts all by itself, all the way up, sounds like it would keep going if it could, then it declines, its stuck in this loop. the belt never starts and I cannot...
This sounds like the treadmill is running an incline calibration. It will run to fully inclined, then to minimum incline.
It should not do this every time you want to operate the machine, but they will do it automatically if the operation of the machine is stopped by the power being interrupted..
Jan 26, 2011 | HEALTHRIDER S600 Treadmill Motor Control...
All the lights are on in the control panel but it wont start even I press start
If they incline works and the motor will not start the motor controller is defective.
Jan 15, 2010 | HEALTHRIDER Exercise & Fitness
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
The incline of my treadmill started going up on it's own
Hello there:
it is looking like the touch pad is failing, you may want to get it serviced by a certified technician. best regards mike
Aug 08, 2009 | HEALTHRIDER S600 Treadmill Motor Control...
HEALTHRIDER R60 SoftStrider Treadmill Logo
309 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
