My toshiba laptops lights come on when i push the power button, but the screen remains black. why wont my computers screen come on
  • 591 Answers
Do you hear a beep when you turn on the computer???, does it seam to power on???, it could be a defective inverter (part that produce the back light of the LCD panel), try plugging an external monitor to see if you have a picture, if so than the LCD panel is defective (LCD it self or INVERTER) if not than it could be the computer it self that wont BOOT, try removing all components (DVD drive, battery, mouse, etc...) see if it turns on...
Good Luck!
Posted on Mar 16, 2011
Toshiba no powerlight when pressed just loops and power light and keyboard blinking light
very likely your video chip is gone. This is a motherboard issue. You have to take it to a local computer store to fix. the might have to reset your computer video chip.
Dec 30, 2013 | Toshiba Satellite A135-S2276 Notebook
Screen wont come on, on my Toshiba laptop computer
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel.
Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on.
If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective.
If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps.
Jan 15, 2013 | Toshiba Computers & Internet
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
The laptop needed charging. After charging, when the power button was pushed, the screen remained black. The power button is lit. What is the problem?
Sometimes when you reset the computer, that happens. disconnect the AC and count to 10. Plug back in. If that doesn't work...turn on from the power and that should automatically reset the screen.
Nov 27, 2010 | Toshiba Satellite A135-S4527 Notebook
Hello, ...My wife purchased a Windows 7 Home Premium 32 Bit Toshiba Satellite L455D-55976 laptop.it has been running well for this afternoon she went to turn it on by pushing power button to display...
is this a brand new system ? if so, bring it backl and have the correct the issue.. it is under warranty
if its used computer , did you get the CD recovery set ?
Oct 17, 2010 | Computers & Internet
Power Light on but screen black
Try powering up with no battery connected. If that works then the battery may be faulty or too old.
Feb 15, 2009 | Computers & Internet
Toshiba A75 Wont Boot up
It sounds like you may not have made a good connection to the motherboard from the screen when you put everything back together.
When you press the power button does the screen come on and then go off or does it not come on at all ?
If it comes on then turns off try to eject the CD-Rom that will be a definitive test of whether your power is still on, assuming your cd-rom is not totally mechanical.
Jan 29, 2009 | Toshiba Satellite A75-S226 Notebook
Laptop motherboard
could be bad screen ok or video controller will have to have parts to test
Sep 05, 2008 | Toshiba (P000204210) Motherboard
Laptop Screen is Blank
there is a hole on the back usually goldish inside take a pen push it in there hold for a couple seconds and press the power button
Jan 26, 2008 | Toshiba Satellite M35X-S349 Notebook
My toshiba laptop will not turn on...
Here is the fix my toshiba laptop also wouldent turn on so i call them and here is what you do 1. unplug the laptop
2.take out the battery 3.hold down the power button for 20 seconds (doing this drains any excess power fron the unit) 4.put battery back in 5.plug in laptop 6.try to turn it on
hope this helps
John
Jan 05, 2008 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
