Question about Garmin nuvi 200W Car GPS Receiver
Why map disapears and picture of computer&gps reciver apears when you plug the charger or usb connector to charge it so its not possible to navigate
    Genius:
  • 1,043 Answers
It sounds like your basic operating system may have become corrupt in some manner. The picture of the GPS and computer should normally only appear when you connect your GPS to your computer. This will normally let you know that your GPS is synchronized to your computer and is ready for you to copy material over from your computer to your GPS. You can try to reset the GPS to see if that will resolve the issue. There is a reset button on the bottom of your GPS. Turn on your GPS. Then using something that does not have a sharp point, depress the reset button for several seconds, about 10-12 should do it. Your GPS should reset itself and come up with the normal loading screen. If you still have the problem then what you can do is go to the Garmin website and download and install the unit software. If you are unable to connect to your GPS with your computer as it normally would you may have to contact Garmin support to find out how you can reload your unit software.
Posted on Mar 16, 2011
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
What does the cord look like that I reload my maps with, and can I charge my garmin on my computer?
The lead you use to connect your satnav to your computer for map updates etc is a mini USB lead. It has a USB plug at one end, to plug into your computer's USB port, and a mini USB plug at the other which plugs into the power connection on the back of your satnav. You can see a picture of the 2 plugs at http://www.google.ie/imgres?imgurl=http://img.diytrade.com/cdimg/569976/3881242/0/1183083272/USB_A_Plug_To_Mini_USB_8pin_Cable.jpg&imgrefurl=http://www.diytrade.com/china/4/products/3052337/USB_A_Plug_To_Mini_USB_8pin_Cable.html&h=485&w=600&sz=65&tbnid=T8gEg2hWA2whcM:&tbnh=109&tbnw=135&prev=/search%3Fq%3Dmini%2BUSB%2Blead%26tbm%3Disch%26tbo%3Du&zoom=1&q=mini+USB+lead&hl=en&usg=___nuT0o9B3Q-xMFQyUD-FLJTh-iw=&sa=X&ei=hL-pTYroGYaAhQfAhr3dCQ&ved=0CD4Q9QEwAw
You can charge the satnav with your computer by leaving it plugged in for approximately 8 hours. It would take 4 hours to charge if connected to your car or mains charger.
Apr 15, 2011 | Garmin nuvi 255W GPS Receiver
Can you update or download a recent map if your battery is not charged or will not hold a charge?
Your GPS have to be able to power on long enough for you to be able to install any map update. If connected to a computer with the USB cable that came with the unit, most units will draw power through that cable, thereby letting you complete the update. There are also units that either come with wall chargers, or have wall chargers available for purchase. While they are plugged into those chargers you should be able to power the unit up and do your update. You might want to check with the retailer that sold you the unit to see if there is a wall charger available.
Mar 09, 2011 | Garmin StreetPilot C330 GPS Receiver
My Garmin Nuvi 270 will not work when charging on the computer or in the car. It just shows the computer connection picture. Once I unplug it, it functions normally. I would like to have it plugged into...
It's normal for it not to work when plugged into the computer. It's not meant to work so changes can be made to it's software or maps, like updates, through the computer. These would not be possible if the satnav was operating.
When it's plugged into the car charger it should work. The problem is caused by wear on the mini USB socket on the back of the satnav. It appears that the mini USB plug is pushed in fully when it's not. Push it in further and the problem will be solved.
Oct 17, 2010 | Garmin NUVI 270 GPS Receiver
My garmin ran out of charge and when it was plugged in to the car charger it says loading maps then stays on the garmin page and goes no further...
Disconnect the nuvi from the car charger and connect it to your computer's USB port with the supplied cable (or any USB cable you have that fits it), and leave connected overnight (8 + hours).
You should be able to get the GPS to start up as expected after charging via USB port. if this happens again, simply repeat.
Jul 15, 2010 | Garmin nuvi 255W GPS Receiver
I have just purchased a sendai universal home charger, when I plug it is my Garmin 200, and the other end into the electrical socket I get a picture on the screen, looks like a computer with a plug running...
The nuvi thinks you've connected it to the USB port of your home computer. It's charging, so pay no attention to the screen.
If you HAD connected it to the USB port, you would also see the nuvi as a storage device attached to your computer. That's how you can download pictures that you can display on your nuvi. It's also the mechanism used when you update your maps and/or software.
Apr 16, 2010 | Garmin nuvi 200W GPS Receiver
When i plug in my garmin to my car charger, it will only show the screen of it being hooked up to a computer...i can no longer access maps when plugged in to charge
That could be because it is not the correct charger.It is going into interface mode.The small usb port is for downloading maps but I have seen some aftermarket charger that will charge through the usb port instead of the cradle bracket.Thanks
Dec 23, 2009 | Garmin Nuvi 660 GPS Receiver
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
My magellen 3100 battery will not charge
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Problem with Garmin Nuvi 200
hold the battery icon for 8 seconds, which will take you to the test screen then plug in the charger then exit This works on a nuvi 200w.
Aug 15, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W Car GPS Receiver Logo
69 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
