Question about Kodak EasyShare C913 Digital Camera
The camera listed below does the following: when it is turned on, it comes on and the lens goes in and out and turns off. I replaced the batteries with new and it still does it. What do I need to do?
  • 6,831 Answers
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Mar 16, 2011
When I turn the camera on, the lens goes in and out several times. Then the message comes "turn the power off and on again". I tried taking the battery out, pressing the power button for 15 sec...
Hi there this is Lens guide pin problem. 99% chacHi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated e is replacing the lens. but before that try these below.
Feb 01, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
I have a hp photosmart M627 camera. When I turn it on, the lens stays in and comes up on screen with a lens error:M627-31. Can you help please.
<div class="solution-text"> <span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.<br><a href="http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html" target="_blank" rel="nofollow"><br>http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html</a><br><br><b>Fix #1:</b> Remove the batteries fromthe camera, wait a few minutes. Put a fresh set of batteries back in(preferably rechargeable NiMH 2500mah or better) and turn the cameraon. If that didn't work, try pressing and holding the Function or OKbutton while turning the camera on. <br><b>Fix #2:</b>If the camera's batteries ran down completely while the its lens wasstill open, the camera may show a lens error or not start properly whennew batteries are installed. Remove the memory card and keep itremoved, then install the new batteries. When you turn the camera onwith the card removed it may come back to life, as this triggers areset in some cameras. Error E30 (for older Canon's) means that youdon't have a memory card installed, so turn it off, slip in the <a href="/support/t5307069-lens_error_lens_not_open#" target="_blank" rel="nofollow">SD card</a>and turn it on one last time </span> </div> <!-- /solution text --> <!-- helpful bar --> <span class="br"></span> <!-- /helpful bar --> <p class="add-comment"> <a id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1_lnkHeader" onclick="javascript:ShowHideForms('ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1');" lang="6652"><br></a> </p>
Aug 24, 2010 | HP PhotoSmart M627 Digital Camera
Samsung pl 50 camera does not turn on. The lens come out and goes right back in and it beeps as it turns off
Well it seems that the battery of your camera is dead, first of all you can try to change the battery of your camera, you can purchase the battery from any Samsung store or purchase it from internet (online) by following the below link -
http://www.batterystyle.com/samsung-pl50-battery-p-46502.html
or
http://sterlingtek.com/sb10-samsung-pl50-battery.html?gclid=CMuQjIn6mqMCFdNR6wod9yIaqQ
or
http://www.buy-battery.ca/digital-camera-battery.php/3+samsung+pl50
or
http://www.batterystore.org.uk/store.php/b-1120191-13803-SAMSUNG-pl50-battery
Good Luck!!
Thanks for using FixYa!!
Aug 02, 2010 | Samsung Cameras
My digital camera has a lens error
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 24, 2010 | Nikon COOLPIX S570 Digital Camera
Lens error, lens do not open
Jul 14, 2010 | Canon PowerShot A1100 IS Digital Camera
When i turn on, it says lens error, restart camera - i"ve turned the camera on and off several times and nothing happens, the error message continues to show. I've taken the battery out and put back in but...
Jul 05, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Lens error :0x01110000 That's what it says when
Jun 12, 2010 | Pentax Optio 60 Digital Camera
My canon A95 comes on and goes off after few seconds.
Try to reset your camera using a command in the set up menu. An error message followed by turning itself off, usually means lens jam. Replace the lens.
Nov 12, 2008 | Canon PowerShot A95 Digital Camera
Green Light Turns on, Sound of turning on, lens comes out, but then goes back in a turns off. . .It's not the batteries. PLEASE HELP ME!
Note that some batteries just don't hack it in digital cameras, even if new. This is especially true for those "super heavy duty" batteries:
http://camerarepair.blogspot.com/2008/02/simple-fix-for-digital-cameras.html
OK, so it's definitely not the batteries. A few of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
May 24, 2008 | Canon PowerShot A540 Digital Camera
Camera lens comes out and goes back in when I turn it on.
Sounds like the lens can't get into the proper position. Any possibility of damage to the lens?
Aug 10, 2006 | Olympus FE-110 Digital Camera
Kodak EasyShare C913 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
