Question about Cisco 3745 Fan Fan Assembly
Hi iam varun, my router is having Fan 4 had a rotation error reported. Version: cisco 3745 (R7000) error logs: Mar 16 22:39:01.369 GMT: %FAN-3-FAN_FAILED: Fan 4 had a rotation error reported. Mar 16 22:39:31.361 GMT: %FAN-3-FAN_FAILED: Fan 4 had a rotation error reported. Mar 16 22:40:01.353 GMT: %FAN-3-FAN_FAILED: Fan 4 had a rotation error reported. Mar 16 22:40:31.345 GMT: %FAN-3-FAN_FAILED: Fan 4 had a rotation error reported. Mar 16 22:41:01.337 GMT: %FAN-3-FAN_FAILED: Fan 4 had a rotation error reported. Mar 16 22:41:31.330 GMT: %FAN-3-FAN_FAILED: Fan 4 had a rotation error reported. Kinldy resilve it
The problem is power supply change the power supply
Posted on Feb 26, 2013
Catalyst 3750 keeps rebooting with an error message platform-1-crashed
Contact Cisco support for a replacement. It is not normal for a switch to reboot like that. Cisco switches (not routers)have a lifetime warranty
Mar 12, 2012 | Cisco Catalyst 3750 24 10/100 + 2 SFP...
Breaking password on cisco 857w
When the router first starts booting you need keep hitting the break sequence which should be crtl+F6 and that should bring you to ROMMON mode. you should get a prompt rommon 1>, that means you did it right. Now you need to change the configuration registers to 0x2142 by typing "confreg 0x2142". then type reset to restart the router. It should now ignore the saved config. hit crtl+c to cancel the initial setup, type "enable" to get to the enable prompt. Next type "copy startup-config running-config" to copy the startup configuration to the running configuration. Next type "configure terminal" to enter global configuration mode. Now you can type "enable secret <password>" to change the password to what you want. Last you need to change the config registers back to 0x2102 by entering the command config-register 0x2102.
Feb 17, 2012 | Cisco 857 ADSL Wireless Router...
SecureCRT - Version 6.2.2 (build 263) [LOCAL] : SSH2Core version 6.2.0.263 [LOCAL] : Connecting to 10.252.105.6:22 ... [LOCAL] : Changing state from STATE_NOT_CONNECTED to STATE_EXPECT_KEX_INIT...
This log shows you are connecting to a Cisco router running SSH protocol version 1, but you have set your SecureCRT to require using SSH version 2.
You either need to either
Set the SecureCRT software to allow connections using SSH version 1
or
upgrade your Cisco device to support SSH version 2.
Apr 15, 2011 | Van Dyke Technologies SecureCRT With...
Iam trying to connect my sony kdl hx 700 to wireless network and my ps3 but my router is a cisco 857 can it be done?
There are 2 models of the Cisco 857 router. You must have the the Cisco 857W in order to support 802.11b/g wireless. The 857 without the "W" will not support it.
Jan 08, 2011 | Cisco 857 Router (CISCO857K9)
How to speed changed in gigabitEthernet 2/1 from cisco 4506switch
Hi
Ok so once you have logged into the router you do the following
go into enable mode by tyoing in en
Then type in conf t
then type in int X where X = the interface
then type in speed 100
then type end
This will set the interface to 100mbps
Feb 27, 2010 | Cisco Catalyst 4506-E Cat4500 E-series...
Cisco 7206 allows telnet but no traffic or ping
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC5.0.1/ipt_system_arch/COL_QOS.html
Sounds like maybe a QOS issue. Click the link above to see if this helps.
Also, could be a load balancing issue. Let me know if this helped.
Sep 21, 2008 | Cisco (1841) Router (cisco1841)
Installation of cisco asa 5510 firewall
If you can't get the manament working initially I suggest the following
Setup a console connection
Type "enable" and press enter to access priveleged exec mode on the ASA
Type "config terminal" and press enter to access configuration mode
Type "configure factory-default" and press enter to load default settings.
Assign a static IP to your PC of 192.168.1.5 and try to browse to https://192.168.1.1 (PC is plugged into management interface)
You should be prompted to begin using ASDM
Jul 30, 2007 | Cisco ASA 5510 Firewall
Computers & Internet Logo
1,168 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
