Question about Acer Computers & Internet
I am experiencing when I turn the laptop on, about 8-10 seconds it turns off. Is this a modulure switch or what? Can I replace this item myself?? What would it cost to be fixed?
    Guru:
  • 689 Answers
Hard drives fail quite like this,if it is a mechanical drive[harddrive] it works like one of those old style record players,there is a disc in the middle then an arm moves across,,bisecting and reading the disc via a small [tiny] head.
if it is in fact a hard drive failure ,its better to try to remove it ,then tap it gently,to see if the mechanism is just stuck,if this works ,then unfortunately it will still fail, at a later date but you will then know the harddrive is at fault
Posted on Mar 16, 2011
    President:
  • 1,768 Answers
1. check to see if you have the PC in sleep mode.
2. check to see if you have a power from the laptop power adapter. You may need a new battery and or adapter.
contact you manufacturers technical support or parts department for OEM parts needed.
Lights on nobodys home
Unplug it, remove battery, hold power button 10 full seconds, reinstall battery, plug in and turn on. It should work fine now. If not, memory stick is likely bad.
Jun 09, 2012 | Samsung Np-r530 Np-r530-ja05us R530 Laptop...
I have installed a garbage disposal under my sink (Badger 5). It is not new, about 2 years old. Brought it from my old house. It worked great before moving it. I wired it in myself. It works when turned...
Smoking electrical device is probably not good news. It implies electrical short.
Freely spinning cutter disk means the sealed motor bearing did not rust out and bind the motor.
Smoking disposal means minimum of melted insulation and overheated motor.
Overheated motors will slow down and stop working.
What caused it? Maybe moving disposal around loosened something.
Decades ago household items were taken to the electric shop and they rewound the motor.
Today metal and copper is landfilled or scrapped to other parts of the world.
I wrote ez disposal replacement steps from when I worked apartment maintenance, but you are experienced already.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My 98 Nissan Altima will try to start (it will just turn and turn but will not catch) . I held it for a second then it backfired... Any suggestions???
I had this same problem with my altima and it had jumped time. you will need to take it to a garage and have the timing belt/chain and gears replaced. with any luck it didn't damage the timing cover cover. I replaced mine myself but if you are not somewhat familiar with working on engines it is best to have someone experienced do it because your can do more damage and cost yourself more money in the long run.
Jul 23, 2011 | 1998 Nissan Altima
I get an HP error message on 2600n printer saying "57 Fan Error". Is it fixable?
57 Fan Error
Turn off then on
The device has experienced a problem with its internal fan.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.The fan is not replaceable. Replace the engine.
Jul 11, 2011 | HP Color LaserJet 2600n Printer
My hp2840 scanner not working display message : scanner error 3 turn off and on please advice
Scanner Error
The device has experienced an internal hardware error.
  • Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.If the error persists, replace the scanning assembly.
Jul 09, 2011 | HP LaserJet 2840 Printer
Hp laserjet 2600n printer has a 51.22 error even after removing the toners
hardware error.
51.22 Error-magenta scanner error
try this:
initialize.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
Laser scanners are not replaceable.
Replace the engine.
Oct 30, 2010 | HP Color LaserJet 2600n Printer
Laptop does turn offf
you can turn off by pressing power button for 15 seconds ..
Feb 16, 2009 | HP Compaq 6720s Notebook
Fog lights staying on
1st most newer car cars have a timer delay that helps light the area you are in for a couple of seconds. You may have had the knob turned all the way up on the turn signal switch. The same thing will happened if this switch is turned all the way up, the interrior light will stay on. Turn the lights on with the switch and see if the fog lights come on, do this without the car running.Trun the lights off,see if the fog lights stay on then go out after a while.if so you have a delay on the fog lights or relay. You may need to replace the relay only. Part $ 15 trace fog light wiring to relay usually under hood away from water sources.......runjoe
Jan 30, 2009 | 2002 Chrysler PT Cruiser
Tele will not stay on
I just started having this problem myself.
Try unplugging the TV for 5 minutes, plug it back in and turn it on. This worked for me and so far it's still working.
Someone said this is a "cold reset" and works for a number of problems.
Good Luck.
Aug 08, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Laptop won't start.
Those are items I would have done myself to test it. It sounds like some item is bad on MOBO (motherboard) it will have to be replaced in any case. I would order a new battery and a replacement MOBO for that unit. If your under a warranty Toshiba would have you send back the laptop to them so they can repair it. Or have local authorized service center send a tech with replacement parts to fix it onsite.
Aug 06, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
