Question about Brother HL-4040CN Laser Printer
Brother Hl-4040CN Hve changed drum How do I reset drum counter? Brother instructions do not appear to work
Press the Go and 'Up' buttons at the same time in the ready status.
The "Reset Parts Life" will appear on the LCD. Select the applicable periodical replacement part by pressing the 'Up' or 'Down' button and press the 'OK' button.
Posted on Apr 08, 2011
  • fordvette May 12, 2011
    Hi Jimmy
    Seems you know a lot about these Brother HL-4040 printers, I have one that I cannot get back to the English language, any ideas.? I have tried the open the tray and everything else between, still no English language.
    Thanx...Gunny
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
How do i reset drum unit for HL4040CDN LASER PRINTER
I have tried to reset the drum counter by the above instructions and have had no luck. Is there anything else that I can do? I would like to reset before I start to use the new drum.
May 17, 2012 | Brother HL-4040CN Laser Printer
My Brother HL 4040cn is telling me I need a new drum??
Many of the current production printers limit the number of copies they will allow to print before changing the cartridge. The cost of printers of all kinds has dropped nicely over time but they will get back their profits by forcing you to replace cartridges, drums, etc. earlier than it is necessary. On some machines, removal and reinstallation of the cartridge may reset the counter but the majority of the machines have a simple device that self-destructs with the first use to limit recycling of the device after rebuild or recharge. There are ways to defeat this trick and many recharging shops know how to replace or bypass this kind of profit booster.
May 06, 2011 | Brother HL-4040CN Laser Printer
I need to reset the drum counter on my Brother HL4040CN printer. I scrolled through the menu to Drum Unit and pressed OK twice - no reset. I don't have a menu item that says Reset Parts life.
Did you follow these instructions?
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000054/faq000154_035.html?reg=us&prod=hl4040cn_all&c=ca&lang=en
Specifically, this part:
  1. Press the + or - button to choose "Machine Info".
  2. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  3. Press OK, and then press the + button to choose "Drum Unit".
  4. Press OK two times.
Apr 20, 2011 | Brother HL-4040CN Laser Printer
There is a warning said : " fuser unit end". What is the problem for that printer HL-4040CN? Even after I changed the drum unit and belt unit, there are still 2 warnings appearing to ask for...
first you are talking about the FUSER END message that means you have to change the FUSER and as for the DRUM and BELT you have to RESET the TIMER to tell the printer that it has been changed as well as for the FUSER those are consumable parts they have a life and the printer is programed to tell you to change them after so much copies.
Jan 05, 2011 | Brother HL-4040CN Laser Printer
I just replaced the drum unit in our Brother 4040cn printer. It still shows on the screen "drum ending soon" how do I reset the drum unit counter?
hello, first did you follow instructions of reseting machine when you replaced drum, if not here is the istructions, with machine in ready state, press go button and up arrow at same time, the reset parts life comes up, use up arrow or down arrow to scroll thru to drum replacement, press the ok button when you get to drum, the machine will have drum unit ok?, press okay, machine will cycle and reset drum.
Nov 03, 2010 | Brother HL-4040CN Laser Printer
Brother 4040CN
This message will appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one
May 21, 2010 | Brother HL-4040CN Laser Printer
Getting a message saying change belt unit...what's that? is it easy to change? Replaced Drum Unit 6 months ago and I still get message Drum Unit end soon.
The instructions to reset the drum after changing are packed with the new drum, and the belt unit is the transfer belt that also wears out and needs changing periodically. The instructions are packed with that also and not hard to change.
Dec 15, 2009 | Brother HL-4040CN Laser Printer
Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Mar 23, 2009 | Brother HL 1250 Laser Printer
Brother HL-4040CN Laser Printer Logo
986 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
