Question about Bernina 1008
Both dials on the right spin when I try to sew. I try to tighten them, but they won't stay tight and the needle won't move (kind of stuck in bobbin winding mode)
    Scholar:
  • 89 Answers
First make sure that the bobbin winder clutch (handwheel) is tight. DO this buy spining the small ring all the way clockwise. Then make sure that the butonhole dial is set to top dead center. then Also check to make sure that the the top stitch slector is set to straight stitch.
If any of this was not the problem then look at the botom of the nobs there should be a small hole. in that hole there is a set screw that may have come loose. you will need ether a small flat head screwdriver, or a alen rench 1.5 or 2.0 mm. let me know if this did not fix it.
Posted on Mar 17, 2011
My needle will not go up and down
hi Tamara.
you have not said the make or model.but try this.
Make sure the push your bobbin winder to the right then to the left and see if that solves the problem. Your Old Machine has a Clutch & It Needs to be Released. The Clutch is this little dial that is inside of the hand wheel. In older machines, it was used to wind the bobbin without the needle going up and down.17 Jul 2015
My Needle is Stuck! My Hand Wheel Won't Move ... - It's Just Sewing
you could also go to this link and see if it helps.when you go to this link if a small windows open in the middle just close that little window.
My Needle is Stuck My Hand Wheel Won Move HELP It Just Sewing
Nov 20, 2017 | Sewing Machines
Why can't thread tension be adjusted?
Upper thread breakage is usually caused by incorrect threading, the tension being too tight, or the thread is wrapped around the spool pin or catching somewhere in the thread path.
Remove the thread completely from the machine.
Install a brand new needle making sure it is compatible with the thread and fabric.
All About Needles
RAISE the presser foot and rethread the machine making sure it follows the correct thread path (consult the owner's manual). Verify that the bobbin is spinning the right direction in the bobbin case and the bobbin case is properly threaded.
Set the upper tension somewhere around the midway point between high & low numbers.
Retest.
If problems persist, there may be debris buildup stuck in the tension disk. Remove the thread. RAISE the presser foot, set the tension all the way to zero. Dampen a length of pearl cotton with rubbing alcohol and gently pull the pearl cotton DOWN through the tension disk a couple of times. Rethread with regular sewing thread, reset the tension to the midway point and retest.
If cleaning the tension disk does not help, then it is possible the tension disk is malfunctioning or broken. Take it for service.
Feb 22, 2016 | Sewing Machines
The panel lights up and then all stitches blink and there is a beep. No power and presser foot does not work.
1. Remove the bobbin and bobbin case. Try checking to see if the machine will set up without power loss.
If it stays on you need to adjust the bobbin case so it is just tight enough to keep it from spinning. Put the bobbin case in. There are screws on top of the case to loosen. Move the hand wheel each direction and see it move. The screws will allow a bracket to move to a point which will prevent the bobbin case from spinning.
Replace the bobbin. Check the tension. (See instruction)
2. While rotating the hand wheel check the bobbin to see if the needle thread moves across the top of the bobbin without getting stuck. Also, pay attention if the needle hits the sides.
3. If the thread gets stuck the bobbin case will need to be loosened about one hair strand distance.
4. If power loss is still a loss check good connection to the socket. Sometimes making a small bend will correction.
5. Check the connection to the machine. If it is loose you may need to make a very small bend on the connection. They have to be tight.
6. The same thing has to be done with the foot controller.
See attachment for tension adjustment.
Aug 13, 2015 | Singer 8763 Curvy
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
Janome help sewing spandex
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
bent bobbin--replace
thread catching on the bobbin spring or latch on bobbin case check to see that the bobbin is inserted completely & correctly & that you are using the right kind of bobbin .
May 22, 2012 | Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
I have borrowed my Mother's Singer Machine # 1022 to finish a project. I have never used this model before. The bobbin threads are way to loose, which dial adjusts the bobbin tension? Also, what is the...
First check if the top thread tension is too tight. Make sure that there are no burs or other damage on the needle. Next check for lint or bits of thread between the bobbin case sections. Remove the bobbin and run a small screw driver or needle between the two silver plates on the top of the bobbin case.
Check if the machine is sewing properly before trying this next step. Find the right hand screw on the side of the black bobbin case. Make sure that this set screw is tight. Turn it clockwise. Next find the left hand screw on the bobbin case. Turn the screw 1/8 turn clockwise to tighten. Test the thread tension. If the bottom thread is still loose, turn this screw another 1/8 of a turn. Test the tension again. Do not over-tighten the screw. This can damage the bobbin case. Some sewing machine parts stores do have a replacement bobbin case available. One source is http://www.sewingpartsonline.com/singer-1022-sewing-machine-parts.aspx .
The dial with 0 F 1 2 3 4 controls the stitch length. Use the 0-1 position for zig zag Satin stitch (At 0, these stitches are very close together). Position 4 will give a longer stitch for basting. See page 4 of the manual (page 8 of the PDF) listed below. In the center of this dial is the reverse button.
Most Singer manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 1022 is http://www.singerco.com/uploads/download/62d051dd5c881663ac19c0a587e679184d936b18.pdf .
I hope this helps.
Aug 22, 2017 | Singer Sewing Machines
How do I fix skipped stitches?
i work on this kind of machine all the time.but i have never set one up for this type of material.if i was having this kind of trouble on a machine i would make sure the tension for the thread is not to tight because this can cause it to skip.if the material is real heavy it will push the needle away from the bobbin hook causing it to skip .is the needle depth set right.tilt the machine up and watch the bobbin as you spin the machine by hand.the needle should just start to come up then the hook on the bobbin should grab the thread.the hook on the bobbin should be as close as you can get it to the needle with out touching the needle.try putting some of the material on the machine while you run it by hand and watch needle and bobbin.if you need to adjust the machine their are two bolts on the bobbin block.if you loosen the screws you can move the bobbin closer to the needle. also their is a screw on the needle bar to adjust the needle depth up or down, i hope this will help you out.
Apr 05, 2009 | Consew 255RB-3 Mechanical Sewing Machine
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
146 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
