Question about Maytag Bravos MTW6600T Top Load Washer
My washer is making a ratteling sound a few time in the rinse and spin cycle, and when i turn to the clean cycle i put affresh in it and its estimated time is 1:02 mins but it only takes about 5 mins before it beeps that its done.............Please Help I payed almost 1900 for my pair exactly 2 years ago ..........dont tell me im gonna have to dump more in them.
  • Maytag Master
  • 8,220 Answers
Ya gotta be careful about over adding detergent. But the rattling to me sounds like the basket is having trouble engaging. That might be due to a small item of clothing between baskets. This will more often than not display a F-72. Bravos service manual
Posted on Mar 16, 2011
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Suds will not spin out. What can I do?
This machine is designed to use HE detergent which is low sudsing if used in the right amount. If the wrong detergent or too much is used sudsing and possibly an error code of SUDS may occur.
You can run a rinse/spin cycle to help clear the suds, you might have to run this cycle several times until the suds are gone.
If the machine is locked out and will not allow you to start a cycle, try unplugging the machine for 30 seconds then plugging back in. Turn the power on and push cancel/drain. This should let you take the clothes out and start the rinse/spin clean out.
Once you have removed all the suds I would recommend running a cleaner such as smelly washer or Affresh through the machine to remove any hidden residue from the excess soap.
Always use HE detergent in a front loader
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
SD code and washer leaking
Sd excessive suds are detected by the washer during the drain or spin phases of the cycle.
The washer will stop and fill with water and then wait for 5 minutes to allow the suds eliminated so that the washer cycle can continue, After the suds dissipate, you can normally drain the washer and spin out the clothes using a RINSE/DRAIN & SPIN cycle. Make sure that you are using HE (High Efficiency) detergent in the appropriate amounts to prevent excessive suds in the washer. This should prevent the washer from going into this routine.
  1. Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
you can clean with affresh or vingar..let me know..
Sep 23, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
My water has been smelling of sulfur. The clothes I was end up smelling of BO after being worn for only a short time. It isnt that the person is smell it is the clothing. Is there something to be added to...
I found that WasherFresh worked better then the Affresh.  What I really did not like is you cannot touch the Affresh tablets, WasherFresh is contained in a pouch and is not harmful to touch, because of the disolving pouch containing the chemicals.  Also after reading the package the chemicals are not harmful to the environment.
WasherFresh removed the odor causing buildup and I now use it monthly as a preventive maintenance.
Sep 30, 2008 | Estate TAWX700JQ Top Load Washer
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
160 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
