Question about Toshiba Satellite A300-0CF035 Notebook
Hi!! My laptop screen seems to freeze after around 5 - 10 minutes and no work can be done without swiching off the power and restarting it. After login back on it sometimes then comes up with a message that states: Login Failure - Security options failed to login on start up. This seemed to start happening around 2 months ago and seems to have got worse?? Is this easily remedied by running the recovery disc for example or is it more serious?? Thank you for your time, David.
    Guru:
  • 689 Answers
Probably you dont have the correct type of recovery disk,there are many different types,first id check your bios pages(F2 whilst booting) to see the specifications of your system,here you can see the size of your "Ram" memory,get to know these pages,dont alter any values and just save and exit ,,use the "Tab" key to navigate.
This could be just insufficient size of ram memory etc in which case an upgrade would be advisable,be carefull you ascertain the correct type of ram memory,there are many different types and its better you go into your pc shop with the correct specifications.
Also you could use utilities to clean up unwanted data on your system,thus freeing space .
Posted on Mar 16, 2011
    Scholar:
  • 62 Answers
Hi David,
That doesn't sound good at all, but do back up all your documents and run the recovery disk. If you can reset the computer to its factory settings, then you can surely find out whether or not it's hardware related. If the computer continues with this issue even after a full reset, then it's a serious problem.
My HP notebook had a similar issue, and even after 3 or 4 factory resets, the problem persisted. I sent it in and found out the GPU had actually began melting (burned out) due to overheating...
I truly hope your situation is not as severe and can easily be fixed. Make sure to save all your data first!
Best of luck, and I hope this helps!
ASUS T100 stuck at preparing automatic repair message will.not reboot
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode...
Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Nov 19, 2013 | ASUS Tablets & eReaders
The problem started a couple of days ago. My laptop would freeze (blue screen in windows freeze in ubuntu) every now and then. Specially when I was watching movies. Restarting the system would not help...
cleaning you laptop will probably solved the problem, disassemble your unit then if you have blower try blow all the dashes all over it and remove memory card, clean it with an eraser. also look for the fan of your laptop check if its working if its not you must replace it. please send me a comment after you done all of this and you still have a problem.
Oct 13, 2010 | Dell Computers & Internet
Looking for assistance. My father is having some
unfortunatly without a windows xp cd to do a repair reinstall or use the advanced recovery, there is nothing that can be done for this. This is a problem that requires that as part of the solution.
Feb 12, 2010 | Toshiba Computers & Internet
Acer Issue ChkDsk
Seems to be bad HDD. Change it.
Sep 15, 2009 | Acer Aspire 1640Z Notebook
Blue Screen
please remove battery and ac-power for a couple of minutes and then try to reboot the computer.
if it still doesnt work, shut it down, remove battery and ac.
remove ram
connect ac-power
try to boot without ram
remove ac power
insert ram
insert battery
connect ac and try to boot again.
when the blue screen appear, please write down the top line that looks something similar to this:
IRQL_LESS_OR_NOT_EQUAL_ETC_ETC
and the line close to the bottom that says
STOP: 0x000021 (0x000+++alot of not needed numbers)
when you have done that please come back to me.
May 29, 2009 | Acer Aspire 4520-5141 Notebook
BLACK SCREEN
try reseating the memory. in the process use a pencil eraser to clean contacts and see if it works.
Is their a possibility of an overheat with your laptop? i mean, during the time that the laptop froze up, did you notice that the laptop is exceptionally hot?
Apr 09, 2008 | Sony VAIO VGN-FS640W Notebook
HP Pavilion dv6000
hi
Dude very simple, uninstall the graphic drivers completely and reinstall them.
do give me feedback
bye
yasir sardar
Feb 27, 2008 | HP Pavilion Notebook
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
Toshiba Satellite A300-0CF035 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
