Question about Sabrent TV-PC85 PC to TV Converter Box
I connected box to my laptop and able to see output on TV. But the issue is that the screen flickers so fast that i can not even able to read the options after clicking the Menu button. Can you please guide me to resolve the issue?
  • jimiparekh Mar 16, 2011
    By flickering I mean that the screen is getting scrolled from top to bottom rapidly.
  • 902 Answers
You will need to change your monitor refresh rate.play around until you find the right refresh rate it should be a settings obtion within the sabrent software. i have had a few sabrent items and they all fail and give me issues really cheeply made
Posted on Mar 16, 2011
  • brian shevack Mar 16, 2011
    you must change your refresh rate right click on desktop go to properties then 2nd monitor and change the refresh rate
    President:
  • 1,623 Answers
The refresh rate of the tv is not capable of reading the output of the box, or your refresh rate settings on the computer are too high for the tv
  • Martin Murray Mar 16, 2011
    as i said the refresh rate is too high
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
Jun 17, 2015 | Sharp Televison & Video
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Jul 22, 2011 | Samsung LN55C650 TV
Rx 2700 dts keeps flickering on and off causing
Your symptom sounds like a poor digital connection. The receiver is probably configured to prefer the digital feed if both digital and analog are present from a given source. That it blinks the 'analog' indicator means it thinks the digital signal is degraded.
I believe you're using HDMI. If your cable box has either optical or coaxial digital outputs, try one or both and proceed from there. You could also certify the health of the receiver input that's failing by connecting another device (your Blu-Ray?) to it to test it out, or simply borrow its cable.
If the input works with another device THAT would indicate a problem upstream and external from the receiver - cable, output of the cable box. Optical cables are more finicky than coaxial and do not tolerate being routed in tight radious bends.
DTS isn't Dolby. Read up on it here - http://en.wikipedia.org/wiki/DTS_(sound_system)
Jan 29, 2010 | Yamaha RX-V2700 Receiver
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
Lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Apr 29, 2008 | LG 42PX5D 42 in. Plasma HDTV
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Problem with component input and 720p HDMI output
does your cable box have an hdmi output? if it does try an hdmi cable instead of componant cables[ i know the hdmi cables aren't cheap] if not, if the reciever has componant outputs, use them instead.
hope this helps
wg
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
No RGA input detected
through the Remote .. press menu .. and make sure that the VGA output is one that the Monitor can handle (if LCD 1280x1024) ... lower the refrech rate or definition until the monitor 'sinc's
Sep 26, 2007 | V-Stream Xpert 1280x1024 LCD TV Box...
Sabrent TV-PC85 PC to TV Converter Box Logo
338 people viewed this question
Top Sabrent Televison & Video Experts
Lawrence Oravetz
Martin Murray
Are you a Sabrent Televison and Video Expert? Answer questions, earn points and help others
