Question about Garmin StreetPilot 7200 Auto GPS GPS Receiver
My maps are locked - Garmin StreetPilot 7200 Auto GPS GPS Receiver
    President:
  • 1,514 Answers
There's details of how to unlock garmin nuvi maps at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing The street pilot should be pretty much the same as they're both made by garmin.
Posted on Mar 17, 2011
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
Garmin Nuvi 1300 Preloaded maps not available on device
There's 2 possible reasons for this;
1. The map is unselected or
2. The map is locked.
To select the map;
  • Press TOOLS (The spanner icon on the screen that shows WHERE TO and VIEW MAP)
  • Press SETTINGS or LOCALE depending on which is on your satnav.
  • Press MAPS and then at the bottom of the screen press MAP INFO
The name of your map should be shown with a tick at the side of it. If it's not ticked press the map name and it will appear. The map is then selected.
If the map is locked you can find details of how to unlock it at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you need so you can skip to paragraph 2.
Apr 17, 2011 | Garmin GPS
Earlier today i updated my garmin 880, and now i can't search for anything. "no map data available" continues to pop up every time i try to enter anything... also only major highways/interstates...
It's most likely that the map is either not selected or locked. You can find the solutions to these problems at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
Try starting at paragraph 5 of the above link, selecting maps. If that doesn't solve the problem the map is probably locked so go back to paragraph 2.
Apr 12, 2011 | Garmin nuvi 880 Car GPS Receiver
Maps are locked on sd card how do I unlock them to use them?
Normally there shouldn't be a problem taking maps off of an SD card. The only time that a Garmin unit will put lock codes on maps located on an SD card is if the maps were purchased and already unlocked on another unit. If someone tries to then use those maps on a different unit the Garmin system will check to see if they have been accessed already. If they have then the unit locks them out. The only other thing that may be going on is that someone else put a password on the maps. If that is the case then you will have to get that person to give you the code.
Mar 16, 2010 | Garmin nuvi 255W GPS Receiver
My sgh-i617 gps is locked, to force you into downloading maps
Remove the battery for sometime and then reinsert it and power on the device. I do not know what maps you are using. I would recommend google maps v 3.2. Download it from maps.google.com or from m.google.com/maps.
Oct 30, 2009 | Samsung BlackJack II Smartphone
Euor maps say locked when i put sd card in sat nav
You have a "LOCKED" Gps....... you need to unlock it.
Sep 01, 2009 | MyGuide 3100 GPS Receiver
Map freezes / locks up and a colour fault
Try using the web-updater Here,
This can resolve glitches, even after an update.
Regards.
Apr 10, 2009 | Garmin nuvi 205W GPS Receiver
Global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
GARMIN
Each map is locked to the unit serial number. The only way to get the map to work on another unit is to buy the maps and register the map serial number and you will receive a unlock code from garmin.
Go to the following link to unlock the map
https://my.garmin.com/mygarmin/marketing/unlock.htm
May 22, 2008 | Garmin nuvi 350 GPS Receiver
Cant unlock maps
What is the Garmin 510 that can't unlock maps stating exactly? And to Nici07 who said, "Need to unlock device", are you referring to a PIN lock or locked maps?
Dec 10, 2007 | Garmin StreetPilot c510 Deluxe GPS...
GPS Logo
54 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
