Question about Ovens
Need to know how to convert from natural gas to propane. vulcan oven,.. model 60XL77R. thanks!
I am looking to change from propane to gas. Willing to swap parts
Posted on Nov 16, 2011
Would like to change my Vulcan from natural gas to propane gas
most likely they do , but many do not have a conversion kit anymore .
Sep 11, 2015 | Vulcan Ovens
Can you converta lincoln impinger from natural gas to propane
Yes you need to go to your gas company and ask them to convert it to LP use they will change burner orfis hrom Natural use to LP use.
Jan 06, 2012 | Lincoln Conveyor Oven - 1133-000-A
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
The gas orfices were changed to propane from natural gas. What size of gas orfices does this oven require? Or will any licensed gas fitter know this and have them on hand to convert this oven back to...
Sorry to read about your problem, I hope this helps you out.
you will have to contact southbend for that info..it is not a common practice to convert these units.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Southbend SLGS12SC Gas Single Oven
Natural gas to propane?
You have to get a converter for propane. You can call any hardware store in your area. Hope this helps you, if not, you can call me. :>)
Aug 13, 2009 | Maytag Ovens
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
How to check to see if gas stove has been converted to propane
The only thing you can do is look for a little (usually gold) nozzle connected to the orfice
propane burns blue and natural gas has the yellow tint to it
May 01, 2008 | Ovens
Why won't my oven ignite? Vulcan model GC04c
i can get you the error code but dont have my manual at the time.a couple things to check.do you here the clicking sound of the ignitor that ignites the gas?when you installed the regulator are you sure its on right?you should see an arrow on the regulator body and it should be pointing to the oven.also you need 10 inches of water colum (gas pressure)with a propane system where as natural you need less,regardless ill be in touch.
Jan 16, 2008 | Vulcan Convection Oven - VC44EC-208-1
Ovens Logo
80 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
