SOURCE: 18 hp craftsman 2 44 inch cut engine dies when blades engage.
HI
Check wires going to safety switch under seat.
SOURCE: Blades do not spin fast enough to cut grass
If you got the right oem belt,ta\han you can look at the end where the cable attachs to spring and you should see a double nut adjustment loosen nuts and adjust to put more tension on the belt when you put lever into gear for blades to turn then retighten them .
SOURCE: mower runs but blades won't engage.
first check for a blown fuse (owners manual will tell location) next try checking the blade engage switch next check the electric clutch good luck
