Question about Sony KF55E200 TV
Sony we655I put a bulb in sony wega we 655 and it won't stay on when you push on button and thr red lite flashes three times in succession
  • 44 Answers
It sounds like there's an issue with the power system in the TV. This can indicate either the bulb replacement didn't work, the wrong bulb was used, or there may have been other power issues that the burned out bulb might have been a symptom of.
Posted on Mar 16, 2011
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
I changed the tv bulb and the new bulb will not lite i get three red flashs
hello when these bulbs are replaced you must make sure the lamps are fitted securely and also the front cover is fitted securely aswell
regards
shaun
Feb 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony wega #KDF-55-WF-655 won't turn on: goes to standby mode
don't wory sir , may i help you .
this is a not mager problum but sum times technicean is parsnal baneefits besness and fast money making this rongh dignosis and canfused to castamer so don't wory ...
[1] problum is in side tv set in out put voltage form EHT becose your tv is red and green light is ok then SMPS is ok
pls. check with tv techicean and follow sum tips
* voltage check From EHT out put and canacting spear.
* H- out put tangester and cancting sperar
* H out put tarngester base tarminal voltage check if ok then 100% problum is EHT or canacting spaer so don't wory all spear is not very expancive pls.find Best tech.and solve this problum Esely
best of luck...
Jan 30, 2010 | Toshiba CZ36V51 36" TV
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Wont power on
The blinking red light means that the projection bulb ($150+/- online) needs to be replaced. The access door is located lower right side and replacing is staight forward. Sony has a problem with the Grand Wega that it is denying resposablity for. Check it out by Googling "MSNBC problems with Sony Grand Wega". I would like to get a class action suit going.
Jun 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replaced the bulb, now the tv will turn off and flash red light
3 times red light flash shows that lamp cover is not seated / fixed properly.
Please check lamp cover and fix it securely.
Dec 11, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony Wega 60 LCD (model # KDF_60XS955)
below the lamp is a thermal fuse that has opened
Sony Part Number: 191002393
https://www.vancebaldwin.com has them in stock
thanks
scott
May 30, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
60 inch sony wega lcd projection
Possible themal sensor. Easy to bypass too!!! Check with authorized Sony repair facility.
Dec 17, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KF55E200 TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
