Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
What do you do when your printer is jammed? how do you unjam it. konica minolta 1690mf multifunction printer
Gunslinger
  • 62 Answers
SOURCE: Printing from an IBM AS/400 to a Konica Minolta 350 printer
An HP5si PCL5e driver may work for just basic printing.You will not have any extras like finishing or dulpexing.
Posted on Oct 21, 2007
  • 3 Answers
SOURCE: konica minolta 2430 DL paper jam
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Posted on Oct 30, 2007
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
Posted on May 27, 2008
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
How do I fix error code 0018 on a magicolor 1690mf printe r?
You may be able to identify the location of the jam by opening up the printer as much as possible then using a bright light source to check the inner recesses. Removal of the jamming material will be the next major task.
Jan 11, 2015 | Konica Minolta magicolor 1690MF All-In-One...
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
I have a konica minolta 1690mf. paper feed problem error 094
Transfer roller issue. the sponge looking roller across from the transfer belt.
Jun 26, 2012 | Konica Minolta magicolor 1690MF All-In-One...
After changing toners (all 4) my Konica Minolta 1690MF screen says Machine trouble Service call (3C10). Anyone knows what is that mean. On the computer says everything is working fine - your device is...
I have 1690mf and changed cartridges, the 3c10 call engineer appears after printing, paper jammed. Had call out from service engineer, afraid he's at a loss too, says it is a security issue but no instructions on how to repair, waiting now to hear from Konica theselves as to what is the answer, I can still print, just have to take the paper out and switch on an off when it stops, annoying though
Mar 25, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
I have no driver and can't load a driver for My Mac OS X 10.6.6 for Konica Minolta magicolor 1690MF
Open this LINK, scroll down the page to the section called "Mac OSX 10.6.X - Drivers" and download your drivers. Hope this helps. Good Luck.
Thanks for using FixYa.
Mar 02, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
251 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
