Question about HP OfficeJet Pro K8600 Printer
I need the manual reset procedure for the Pro K8600 printer as I do not recognize a continuous ink cartridge.
  • alxe26 Mar 19, 2011
    It only has 3 buttons, power, cancel, sheet feeder.
    What happens is it shows me the drop of the black cartridge, and I can not make the impression.
  • 2,574 Answers
Power Drain:
Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
Press and hold the Power button for 60 seconds.
Connect the cable and turn ON the printer.
Partial Reset:
Remove the power cable from back side of the printer while its ON.
Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
If printer turns OFF, press power button to turn it ON.
Semi-Full reset:
Remove the ink cartridges.
Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
Insert the ink cartridges.
Full-NVM Reset:
Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Posted on Mar 18, 2011
  • 1 more comment
  • Reparatii PC - Service IT
    Press and HOLD the power button, the X changes to a
    unit code factor of 10, and the page button changes to a code factor of
    one. DO NOT do this code with the network cable plugged in
    To enter 230, press and hold the power button (light
    goes off but unit stays on), then press the X button 23 times, Let them
    both loose. Wait about 20 seconds, and print yourself out a
    configuration page (by holding X until printer starts working to print).
    The printer will not recognize the black cartridge
    Take the cartridge out and put it back in several times. Turn on and
    off the printer and unplug and plug back in the printer. Try putting an
    old black cartridge in and see if it reads it. Then put the new one
    back in. Repeat these steps several times. If it reads the old
    cartridge you may just want to buy a new ink cartridge. If none of
    these work you can always send it in for repair
How to reset HP Ink Levels Printer hp officejet pro k8600
the only way to reset ink levels is to replace the cartridge(s). If you're refilling, you need a second set of cartridges and use them in rotation with the first set.
Aug 29, 2014 | HP OfficeJet Pro K8600 Printer
Reset cartridge
hp do not accept that procedure
I am one of hp tech. Support in worldwide
hope help you
Mohamed Hejazi
HP Tech.Support
Nov 10, 2013 | HP OfficeJet Pro K8600 Printer
HP 8600 New Setup ink cartridges not recognised
Hi Alan,
Is this brand new printer ? Check the Warranty on it, Ideally warranty starts from day 1 you purchase the printer.
If it is asking you to use Setup cartridges, you should try contacting HP Support.
1-800-474-6836
Regards,
Sean
Feb 14, 2013 | HP OfficeJet Pro K8600 Printer
Hp Officejet Pro K600 is not printing black and making the other colors appear saturated and dull
Your ink cartridges seems to be dry/near emtyness, buy a new black and color cartridges and it will print as new.
Nov 29, 2009 | HP OfficeJet Pro K8600 Printer
For some reason my HP Officeject Pro K8600 is reading empty yellow ink cartridge even after I replace it. I have replaced the cartridge several times with a new cartridge but it still won't work. Why? ...
The mount that holds the spring for the yellow ink cartridge pump arm in the service station is probably broken. You will have to replace the ink-service station.
Sep 15, 2009 | HP OfficeJet Pro K8600 Printer
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
HP OfficeJet Pro K8600 Printer Logo
2,492 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
