Question about HP Photosmart Premium C309A All-In-One Printer
Hp C309a . lights flashing on control panel. code CSFE0082
  • dougsticklan Mar 19, 2011
    when lid is open ink cart stays on right hand side
  • HP Master
  • 4,924 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3737195#N998
on this page ..follow the instructions on the chapter any other error code ...
but ..for the reset ..I'll recommend to unplug...than after 20 seconds..keep the power button pressed..and than plug it again ...and keep pressing the power button ...for at least 10 seconds....
remember to unplug the unit while is on ...
if this reset would not work ..follow the next steps to clean it ..and see if this will do ...after cleaning ..reset again ..
Posted on Mar 20, 2011
    Genius:
  • 1,157 Answers
Hi dougsticklan,
The best way to test and correct this issue is to perform a system reset. The importance of system reset is to verify if you have a software of hardware issue. Here are some steps that you can apply on how to reset the system.
1. Press the power button to turn on the machine.
2. While system is turned on, disconnect the power cord from the rear of the system.
3. Unplug the power cord from the wall outlet.
4. Wait for at least 15 - 2- seconds.
5. Plug the power cord back into the power outlet.
6. Now, reconnect the power cord to the rear of the system.
7. If the system does not turn on by itself, try to press the Power button to it.
If the previous steps did not resolve the issue, try to check the print head it might be installed incorrectly. Please follow these steps to check and clean the print head.
1. Turn on the system.
2. Open the cartridge access door.
3. Now, to remove the cartridge, press the tab on the front of the cartridge to release it and remove it from the slot.
NOTE: Do not leave the cartridges outside the product longer than 30 minutes. Doing so can result in damage to both the product and the cartridges.
4. Please lift the latch handle on the cartridge until it stops.
5. Lift the print head straight up to remove it.
6. Clean the print head.Ensure to clean the plastic ramps on both sides of the ink nozzles, the edge between the ink nozzles and the electrical contacts, and the electrical contacts.
--> if previous solutions did not resolve the issue, I recommend to contact the manufacturer for further diagnostics and repair. Please refer to the link below.
HP Contact Information
Hope it helps.
Thank you for using FixYa.
Posted on Mar 19, 2011
  • 2,574 Answers
Navigate to this page and follow the instructions from the article !
  • HP Master
  • 6,993 Answers
First, try the steps below;
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the printer.
3. Wait for the "Insert Cartridge" message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
If the above doesn't solve the problem, please let me know so that I may direct you further.
Good luck.
Posted on Mar 18, 2011
Can't uninstall hp series 309a from programs
1. Disconnect printer from the computer.
2. go into control panel, printer, and remove the printer in the from the printers section.
3. Go to control panel and remove all the software associated with the printer.
:) good luck.
Jan 23, 2013 | HP Photosmart Premium C309A All-In-One...
HP Premium All in one printer c 309a all lights keep flashing.
Have you tried unplugging the printer from the wall for 5 minutes to reset it? If that doesn't work you either have a defective ink cartridge or the printer is defective. Due to the very low prices of new printers replacing it in almost all cases is the cost conscious thing to do.
Jan 16, 2012 | HP Photosmart Premium C309A All-In-One...
How can I clean the print heads on my H: photosmart C309a printer?
  1. Push the Setup button on the control panel.
  2. Push the down arrow until Tools is highlighted.
  3. Press OK.
  4. Push the down arrow until the Clean Printheads option is highlighted.
  5. Press OK.
I am an HP employee. I do not represent HP on this site.
Nov 27, 2010 | HP Photosmart Premium C309A All-In-One...
Windows could not start the spooler service on local computer when trying to connect hp c309a printer
If you the print spooler isn't working, you can either manually turn it off and on by going into your control panel - Administrative Tools - Services - Print Spooler - Then click the restart button.
The other easy option which usually works is just restarting your computer. This will restart your print spooler as well.
Hope this helps! :)
May 03, 2010 | HP Photosmart Premium C309A All-In-One...
HP309C
We have a new wireless network. How do I change the wieless network that my HP 309c is using to print?
Jan 02, 2010 | HP Photosmart Premium C309A All-In-One...
Photosmart c309a fax confirmation?
To enable fax confirmation via the device control panel
1. Press Setup.
2. Select Print Report, and then Fax Confirmation.
3. Select one of the following: On Fax Send, On Fax Receive, Send &
Receive
4. then press OK
Dec 11, 2009 | HP Photosmart Premium C309A All-In-One...
HP Photosmart Premium C309A  All-In-One Printer Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
