Removing the agitator to replace the part beneath just pull up on it????
  • 1,998 Answers
When you go to remove the agitator you would use a 7/16 socket to unscrew the agitator once this is done then you can pull up on the agitator here is a video showing how its done if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
heres you video http://www.youtube.com/watch?v=0GQh8JLqVv8
Posted on Mar 16, 2011
Item caught under agitator
The top of the washer pulls up. IT may be hard to do. This will expose the whole drum so that you can see around it. If you need to remove the agitator, there is a cap on the top of the center, take it off and you should see a nut and some lock washers, Remove the nut and lift the agitator out.
Dec 19, 2013 | GE Washing Machines
I have read the instructions for removing the agitator, but my machine does not seem to allow me to get to a bolt or nut. I have removed the cap from the agitator, but the barrier cap and seals do not...
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets your needs, ..Thank you.
Jul 17, 2011 | Kenmore 22422 Top Load Washer
Clean under agitator on a Kitchen Aid top loading washing machine.
To remove the agitator to gently remove the cap from the top - it will have a rubber o-ring seal. Beneath it there should be a nut and washer assembly remove that. Then there should be a stack of agitator parts - clutch, upper agitator, lower agitator. Set them aside in the order you remove them. then back in the opposite manner.
Hope this helps.
Joseph
Apr 16, 2011 | Washing Machines
Diplomat ADP 8322 - 11 Flashes. Will not go beyond the Rinse cycle.
There's never a good time for the washer to stop working correctly. If a washing machine's agitator isn't working properly, your clothes won't come clean.
The back-and-forth movement of the agitator is a main function in the cleaning process of your laundry.
If your agitator isn't working, it could be the agitator itself or broken splines in the assembly beneath the agitator. Either one is a relatively easy and inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
  1. Inspect the agitator for breaks. If the agitator is broken or cracked, you'll need to replace it. A broken agitator won't operate correctly, if at all. If the agitator looks fine but isn't moving, you'll need to inspect the plastic splines in the agitator assembly located underneath the agitator.
  2. Remove the agitator from the washing machine by first removing the fabric softener dispenser cap on top of it. This cap should either pull or screw off. It it's difficult to remove, you might have to pry it off.
  3. Unscrew the bolt beneath the softener cap with a socket wrench. Once you've removed the screw, try lifting the agitator out of the washer. If it doesn't easily lift out, loop a rope underneath one side of the agitator and over a broom handle. Continue looping the rope under the other side of the agitator and back over the broom. Using caution not to hit yourself in the head, pull up on the broom until the agitator comes loose.
  4. Replace the broken agitator with a new one. Snap the new one in place and secure the bolt underneath the fabric softener cap. Place the cap back on the agitator and you're ready to start washing.
    Check the plastic splines in the assembly directly underneath the agitator, if the agitator itself isn't broken. If the plastic splines are broken or worn down, this will keep the agitator from properly moving. In fact, it might not move at all. Replace the spline assembly with a new one and reassemble the agitator by reversing your steps to remove it.
Good luck and thanks for using fixya.
Dec 24, 2010 | Dishwashers
How do i remove the agitator ??
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some washer may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
Mar 03, 2010 | GE WBSR3140DW Top Load Washer
Agitator issues
The agitator coupling beneath the agitator needs replacing. It is stripped.
Pull hard on the agitator to pull it off the shaft to expose the coupling. Remove the coupling and replace it with a new one. Replace the agitator.
If the agitator is hard to remove,use a old leather belt under the agitator to pull up on.
Watch your nose when it comes loose.
Feb 18, 2010 | GE Washing Machines
Agitator removal to remove clothes stuck beneath
for the basic top loader there should be a cap on the top of the agitator you can pop off with a flat screw driver and then use a ratchet with an extension to get to the nut holding the agitator on, 1\2 inch or 9\16 socket, i think.
Dec 12, 2009 | GE Washing Machines
I have a kenmore washer and I am trying to replace the cam dogs. I have removed the dispenser cup and the cap that is beneath it. I can see the edges of the cam dogs, but cannot remove the plastic thing...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 31, 2008 | Washing Machines
Object caught beneath the adigator
Remove the fabric softener by pulling and pushing to one side.
Once removed, there will be a half inch bolt that holds the agitator to the transmission shaft. Loosen the bolt and the agitator will lift off.
Older Hoovers have a set screw near the middle of the agitator.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Jun 21, 2008 | Hoover Washing Machines
Calypso Washer, seems unable to turn drum or agitate
I haven't had the problem with the washer tearing up my clothes as of yet but I have with the c1 error code. According the the manual there are three possibilities. 1- Bad drive motor 2- Bad thermal protector ( solution to fix replace the drive motor) 3- Bad motor control board. The last one was what needed to be replaced in mine.
Feb 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
