Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phiips model #60PP9202 -Green cast
I bought this TV used. The owner said the TV quit and took it in to get repaired and told me if I paid the repair cost I could have it. So I did, The TV repairman said it had a short and fixed it. I brought it home and turned it on and the Whites and blacks have a strong green look. I asked the old owner of the TV to come look at it and she said it did not look like that when she used it. Any ideas?
  • 3 more comments
  • fnmike Aug 02, 2008
    Thanks Slinteriors. I'll buy that kit and give it a shot.
  • fnmike Aug 16, 2008
    Slinteriors.. I ordered that kit two weeks ago and was curious when I should expect it..
    Thanks, Mike
    OK.. Thanks guy.. I really do appreciate all your help!!..Your the most helpful guy I have found so far. I have total faith in you and I'll be sure to let you know how all this turns out.
    Thanks again, Mike
  • fnmike Aug 20, 2008
    I got my coolant kit today..How does that front grill come off?
    Ok.. I'll be doing all this this weekend it seems like it might pop off but the very bottoms seem to be very snug.
  • Philips Master
  • 8,617 Answers
Your CRTs need the coolant changed. Its a common condition in phillips models. You can get the coolant repair kit which contains all the coolant and the instructional cD that does step by step instruction with pictures of the entire replacement procedure
Posted on Aug 02, 2008
  • 4 more comments
  • Sonny Berry
    Sonny Berry Aug 02, 2008
    sorry heres the link.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    You will be glad you did. the colors will be just like new. I am always amazed at the difference evrytime I do the coolant change on a phillips / magnavox.
  • Sonny Berry
    Sonny Berry Aug 16, 2008
    It takes a while cause since 9 11 all liguids have to be go through special handling such as being inspected, it usually takes me close to 3 weeks you should be getting it soon.
  • Sonny Berry
    youre welcome, be sure to take advantage of their free tech support if you have any questions about the proceedure when your kit arrives, as they will help you out with whatever additional help that you may require.
  • Sonny Berry
    Sonny Berry Aug 20, 2008
    most phillips speaker grilles if you dont see screws just pop off
  • Sonny Berry
    some of those do hav a few screws along the bottom edge you almost have to lay down to see them
Faulty Samsung lcd tv LE40R87BD
Prices continue to drop precipitously and a repair or replacement of the board is gonna be expensive. Better off with new set and new warranty.
Aug 03, 2017 | Televison & Video
I have a Phillips rear projection TV, model 60pp9202. I think I have a convergence problem because the picrure looks cruved and the colors are mostly red and green. The wording or text looks like it has...
Gary, If you can solder you can do the repair yourself which will consist of replacing both convergence ICs and possibly one or two of the low ohm resistors. You can get the Phillips DPTV305 - DPTV345 convergence repair kit which also fits your model which contains the ICs, and all 12 resistors and the CD with detailed repair instructions from www.tvrepairworld.com
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
I have a TV 60PP9202/17F, the convergence the Red to the Green does not work.
Install the convergence repair kit. The Phillips DPTV305- DPTV345 convergence repair kit from www.tvrepairworld.com is the correct kit for your model. The kit contains the two ICs and the 12 resistors plus the CD with repair instructions.
Apr 01, 2011 | Philips Televison & Video
I called the store where we bought our tv and told him the problem, in just two sentences he told me what was wrong and that was happening to all the projection tvs and they quit making them. I ask why he...
Whats the model number of your TV I should be able to help you locate the part you require along with the instructions for replaceing it without costing an arm and a leg.
Mar 11, 2010 | Televison & Video
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
Line red,yellow,green are all over picture and images
No you will need to replace the Convergence Ics and possibly some of the 12 feed resistors. You can get the repair kit for your model at the following link which contains both cinvergence ICs and all 12 resistors plus free instructions with pictures so you can do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
May 25, 2009 | Philips 60PP9202 60" Rear Projection...
Pt-52lcx65 52 in.
call panasonic customer service....open a claim....problem is most likely that the eprom needs to be reflashed.....i contacted them several weeks ago, told them my problem which was 5 baseball sized colored spots, 1 red, 2 blue and 2 green. they had me perform a couple of tests using a dvd. when i reported the results they set up a service call with a local authorized repair shop. results were amazing. reflashing the eprom took about 4-6 minutes. in addition my brilliant color returned to the set as well as another problem of neon images going away. this was paid for by panasonic. my set was 2 years over warranty. panasonic has issued a service bulletin on this and are backing up these units.
pt-61lcx35
hope this helps, i am quite satisfied with what was done.
Dec 18, 2008 | Panasonic PT-52LCX65 44" HDTV
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Phiips 32pt5441/37 problem
Hello tvpassword,
It sounds like a power supply problem, or at least a startup issue. This might be caused by any number of problems, but I would suspect that it, the problem that is, is in the Horizontal section of your set. If this is the case I would suggest that you get this TV repaired at a qualified TV repair shop, due to the section of the TV that is involved, dangerously high voltages are present and could cause bodily harm if a mistake is made.
If you are going to attempt to do this yourself I would advise that you know electronics before attempting this, if you do not, my first statement stands.
I hope this helps,
Shuttle83
Aug 05, 2008 | Philips 32PT5441/37 32" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
