Question about Philips 32PFL3504D 32 in. LCD TV
How do I remove the stand from myPhilips 32PFL3504D 32" LCD TV
SOURCE: akai 32"
I just purchased this unit and briefly looked at removing the stand though I haven't taken it off yet. Anyways, I think you need to remove the black metal mounting frame from the TV before trying to unscrew the stand (4 screws) from the metal frame. After the frame is off the TV, I think you can then get at a couple of hidden screws to remove the stand from frame. I don't know if the frame goes back on the TV or not.
Posted on Dec 03, 2007
SOURCE: Wall mounting Panasonic Viera 32" tv
Took me a while to find this. Remove the two lowest screw, holding on the plastic back, in the centre and it drops out.  -- Andrew
Posted on Apr 27, 2008
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
SOURCE: Lost screws for for my 32" polaroid LCD TV stand
M5 X 18MM
Posted on Aug 19, 2009
1joester2
  • 74 Answers
SOURCE: I have an HCT LCD TV. It is an 32'' and I can't get the stand off.
"S" = Stand.
Remove the 4 screws and pull the stand straight off the bottom.
Joe
Posted on Jan 04, 2010
Testimonial: "Thank you very much. It worked!!"
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
I have a boken screen can't seem to find a screen for this model
Hello; If you could find a new LCD Panel, It will cost more than double the original selling price of the set. Unless the set is of extreme nostalgic importance, toss it. John
Jul 06, 2011 | Philips 32PFL3504D 32 in. LCD TV
Tv say "no signal" when
Hmm your PS3 should not be using AV out because your game signal is going into your TV, Try using HDMI 1,2, or 3 also there should be av in components in your TV as well.
Jul 02, 2011 | Philips 32PFL3504D 32 in. LCD TV
Hello I am repairing a philips tv 32pfl3504d/f7. I replaced the main power supply CBA and the inverter CBA and still have the same problem. The power light comes on when the unit is plugged in and blinks...
This problem it is the main tv Tuner signal board it is dead also.Beside the power supply board.This problems have nothing to do with the long LCD invert board.
Jun 07, 2011 | Philips 32PFL3504D 32 in. LCD TV
I am trying to add a sound bar to this model tv any suggestions as to a compatible one?
Hello:
The Philips 32PFL3504D TV has several audio outputs that are are compatible with sound bars. You want to be looking for a sound bar with a Digital Coax audio input.
For example: http://www.amazon.com/Sharp-HTSB300-System-Digital-Decoding/dp/B001R4CJS4
A Digital Coax audio input looks like an RCA jack and is usually colored orange.
Mar 06, 2011 | Philips 32PFL3504D 32 in. LCD TV
It was working perfect and now I have no picture. I have not moved any cables. Sound still works.
im thinkin an inverter or backlight failure would cause you to have these problems my local shop charges 40$ to open and troubleshoot
Jan 13, 2011 | Philips 32PFL3504D 32 in. LCD TV
I can't get my dvd to operate. I haven't used it for some time and have forgotten all i ever knew.
Post the make and model on here and someone should be able to find an owners instruction manual for you.
Jul 09, 2010 | Philips 32PFL3504D 32 in. LCD TV
How to remove stand on vivo 32 inch lcd tv
if you send picture to semirengeee@yahoo.com , i can try to help you
Sep 12, 2009 | Televison & Video
I am tring to connect my PC to my philips 32pf9631D plazma TV useing HDMI to HDMI cable but cannot get a piture up on the TV. Tried another monitor usung same cable, it works. Is there some special setting...
for the plasma tv, go to the menu and try to find some options about the HDMI on the menu or go through the user manual you will definitely find some solutions. or try to change the HDMI cables.
Aug 10, 2009 | Philips 32PFL3504D 32 in. LCD TV
Philips 32PFL3504D 32 in. LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
