Question about GE JE1640WA/GA Microwave Oven
How do I remove the control panel on my GE model JE1640WA microwave? I've removed the front/grill but I can't find any screws or latches holding the front of the control panel on...what am I missing?
  • 7 more comments
  • jillandbenny Mar 16, 2011
    I watched the video you referred me to...it doesn't answer my question...my GE microwave does not have the obvious screw holding the control panel...as I stated in my original question.
    So I still need instructions specific to my microwave for removing the control panel.
    How do I remove the control panel on my GE microwave model JE1640WA? There are no obvious screws of latches holding it on...but I'm reluctant to try and pull or pry it off.
    Kevin---The answer/video you offered doesn't answer my question. My control panel does not have an obvious screw holding it on...as stated in my original question. I still need an answer to my original question.
  • jillandbenny Mar 17, 2011
    How do I remove the outer case...that's my problem. There are no obvious screws/tabs/latches holding it on.
    My problem is this: my microwave (GE Model JE1640WA) stopped working; I'm pretty sure the problem is with the switch that is activated when the door closes thus allow the microwave to turn on. In order to get to this switch I needed to first remove the front panel/grill....done that, no problem. Next, I need to remove the control panel...that's my current problem...there are no visible screws/clips/brackets to allow removal of the control panel (unlike the Sharp microwave shown on the video on the FixYa website). Perhaps the cover of the control panel has to be pulled/pryed-off to get access to screws that attach the control panel to the microwave...but I'm reluctant to try this without knowledge that it's the right way to go about it. Does that help explain my problem/question? Can you help?
    Okay...and how do I remove the outer cover...pry it off with a screwdriver? This will undoubtedly leave some ugly pry marks on the plastic cover. I would have expected there to be a more elegant solution/way to remove the cover. No?
  • jillandbenny Mar 18, 2011
    I'm still looking for an answer as to how to remove the control panel from my GE Microwave Model JE1640WA. I've removed the front cover/grill. There are no visible screw or clips to remove to get the cover off of the control panel. I'm reluctant to try and pry the cover off with a screwdriver or such...this will surely damage the plastic cover. There must be a trick to getting this cover off...but no one seems to know what it is.
  • jillandbenny Mar 19, 2011
    Finally, TheMobilian actually read/understood my question and posted an answer that enabled my to repair my microwave, and it's cooking oatmeal as we speak. Sounds like TheMobilian may be in/from Mobile, AL....whether or not, this DauphinIslander says thanks big time for the help.
  • GE Master
  • 8,220 Answers
Interesting video of how to get into a GE:
Service manual of a late model GE
More here
Posted on Mar 18, 2011
    President:
  • 2,468 Answers
You need to remove the outer cover around the top and sides,then discharge the high voltage capacitor before reaching in the unit,the control panel screws will be in there holding the control panel,facing outward
Posted on Mar 17, 2011
    President:
  • 739 Answers
HI...
The controller usually includes a microcomputer, though very inexpensive units may simply have a mechanical timer (which ironically, is probably more expensive to manufacture!). The controller runs the digital clock and cook timer; sets microwave power levels; runs the display; and in high performance ovens, monitors the moisture or temperature sensors
to resolve all the difficulties, I'll be happy if you could explain in more detail the problem of your microwave oven?
regards
  • HTS Sri Aman
    HTS Sri Aman Mar 18, 2011
    Most microwave door switches can be tested for continuity( CLICK HERE ) to see if the switch has failed. This can "fool" you sometimes. This switch looks fine, tested fine with an ohm meter and even made the "click" noise ok when we pressed on the actuator button.
    BUT,
    Once we opened up the switch, it became clear this switch's contacts where being overheated and failing = new switch time.
    This switch "looked" ok, "checked" ok with an ohm meter...but as you can see...it is not ok.
  • HTS Sri Aman
    HTS Sri Aman Mar 19, 2011
    If there is no other way that allows the control panel is removed, it require you to poke the plastic cover carefully to detach the controller. If it's not a burden for you, I hope you can upload a front and back part of the controller photo, is so i can investigate the suitability of a way to open it.
  • 1,543 Answers
Remove outer case. Remove screws holding keypanel / control board asm. Remove ribbon connector from key panel to control board. Remove control board. Remove keypanel. (may be stuck on w/ double face tape or held with metal tabs bend over protruding from the front side of a trim piece.
  • GE Master
  • 1,902 Answers
Hello & Welcome to FixYa
Please check this video for control panel replacement:
Please get back to me if you have any other questions.
Kevin
Posted on Mar 16, 2011
  • Kevin White
    Kevin White Mar 17, 2011
    Then just go to next step in video and take out the control
I have a GE Microwave Model # JVM133OBW. The interior light went out. How do I replace it?
Typically you remove the vent cover just above the door that goes all the way across the top of the unit. There are 2 or 3 phillips screws in the front of it, or on top. You take out that plastic vent grill and look behind it. There is another screw in the center that holds down the panel the light bulb is held in. So, remove that screw and lift up on the panel holding the bulb. Make sure you unplug the Microwave before you take out the bulb. Sometimes the glass will seperate from the base and the wires inside will twist together and blow up your circuit bosrd. SO UNPLUG FIRST!!! On that top grill some have the screws on the Top of the unit, but you just have to find the screws that hold that top front grill in place. Some of the grills have to slide to the side a bit to come out. I am sorry I do not have exact instructions on YOUR machine. But it really is not that difficult. It could be a screw in type bulb or a small push in Halogen. Good Luck
Oct 16, 2017 | GE Microwave Ovens
Where is the fuse located in a GE Spacemaker II microwave model number J EM824_ _ _ ? I can't read the rest of the model number.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE MICROWAVE MODEL JVM1750DM1WW NO POWER AT ALL. HAVE ALREADY CHECKED THE OUTLET AND CHECKED THE BREAKER. ABSOLUTELY NOTHING WORKING.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. replace fuse and microwave should begin working.
Feb 09, 2011 | Microwave Ovens
MICROWAVE IS DEAD. IT CAME ON FOR 3 SECONDS AND THEN WENT DEAD. NO LIGHTS NO CLOCK NO NOTHING. IT IS BUILT IN OVER THE OVEN. IT WAS MANUFACTURED IN 1998.
sounds like you may have a blown fuse. . remove the 2 screws at the hop thats holding the ventillation grill. remove screw holding control panel. push control panel up slightly and lift out. . there should be another metal sheet covering the opening. remove and your fuse should be right behind that.
Feb 04, 2011 | GE JE1640WA/GA Microwave Oven
When microwave finishes light doesn't come on when door open; display keeps reading "food ready" after food is taken out--have to push the "clear/off" button to make "food ready" display go away; counter...
Shorted switch in the door latch assembly.wihout the full model number I can't tell how to get to it, but usually one needs to remove top grille, remove screw holding the control panel, remove control panel. Good luck.
Nov 26, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Fuse location ge spacemaker under the counter
it is behind the control panel.to access that remove the top grill by removing two screws on the top or in the fron of grill.then u should see see a screw on the top of control panel holding it.remove that screw and u should be able to remove the control panel.fuse will be behind the panel.it is not mounted on the panel but in the cavity behind it.
Aug 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do I open the front panel of GE Spacemaker 2.0 ? Fuse?
there are screws either on top of or in the grille that allow you to remove it. after screws are removed, open the door, pull lightly toward you starting at the control side if it does not pull, then it may have to be pushed toward the hinge side, then pulled out. behind the grille, is the screw attaching the control panel. lift the panel up before pulling out. Just to add a thought,if the display lights up it is probably not the fuse, although, in some models there is a high voltage fuse, it is pretty rare.
Jun 16, 2009 | GE Profile Spacemaker Over-the-Range...
GE JE1640WA problem
Chances are you have a bad primary interlock (top door switch) or its mount is damaged or loose.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
(Your mini-manual may show that your primary interlock is the bottom switch, so go by it)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 07, 2009 | GE JE1640WA/GA Microwave Oven
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Removing the control panel on the 1800XL to replace the fuse
Unplug microwave. Remove the two phillips head screws from the top at the very front edge, allowing you to remove the top grill. This will give you access to the one remaining screw holding the control panel in place. Lift panel up a bit and you're in. Note: even an unplugged microwave can hold a nasty electrical charge if the bleeder resister inside the capacitor is bad. Be cautious and don't touch things unnecessarily.
Aug 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1640WA/GA Microwave Oven Logo
280 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
