Question about Radio Communications
Uniden washington PC-385 PCB It has no receive, and no modlation, I replaced the IC4 audio chip, it has modulation now but still no receive, I tried aligning L10- L5 and still noting. it rec when I key up another radio right next to it.
  • rschaniel961 Mar 21, 2011
    Well I replaced the ta7222ap and the and the MB3756 regulator, and still no receive on either ssb or AM the meter isn't even moving
  • 391 Answers
Hi you may need to to change the audio transistor also ,also check with external speaker
Posted on Mar 16, 2011
  • this is a scam website Mar 22, 2011
    hi sounds to me there are other problems along the board check for voltage at ta7222 before and after check ic aswell this could be the source of the problem check all components on the track leaving mb3756 you will source the fault along the track it would be easier if you have an ocilliscope to check the source hope you get to the bottom of it goodluck
A uniden Madison base station with digital clock that transmits and receives but has no modulation
could be your final , could be the modulation transformer, could be your coax, could be your mic. Hows the SWR . under a 2.0 I hope.the smaller the # the better you get out .
Oct 25, 2015 | Uniden Radio Communications
Uniden washington receive ok transmit with no modulation on ssb and am tried two mikes worked previously in the past
check to see if the radio had the diode clipped . If so then replace it to see if thats the problem.
Feb 20, 2015 | Uniden Radio Communications
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Feb 01, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Uniden washington wont transmit on am ,but transmit on sideband
If I remember correctly, this means that a voltage regulator is out. If it doesn't receive either, then the audio amplifier is out. A qualified service person is going to have to look at this for you. You may find a CB Shop near a truck stop if you have any nearby.
Feb 12, 2010 | Uniden Radio Communications
No power to box ic is blown in power psu where can i get replacement as the top has come of chip its the ic1 or 4 chip but cant read anything from chip as no top  need to get it repaired
We can probably look up the part numbers, but we'd need the make and model of the unit. Can you please update this with that info? Also, is the IC marked on the board IC1 or IC4? Hopefully you can also indicate which IC is smoked. When we look this up, we will provide other parts that need to be checked. It is unusual for an IC in the power supply to be the only failed part.
Please update this with the above info.
Thanks,
Dan
Oct 23, 2009 | Audio Players & Recorders
Radio 29 ltd no modulation, no receive and good carrier, no capacitor shorted or blowm,changed ic audio by a new one and get still the same problem
did you change IC4=TA7222AP ?
check input ic4 pin1 is it supply voltage?=12vdc.
check C48 couple cap,also check C39 replace
with a 25 watt and C42 also C45.
check R130 1.1 ohm. also R121 180 ohm.
if pin 1 on ic4 is low volt or missing,check TR23
and D22,C119
maybe this will help some
Sep 28, 2009 | Cobra 29 LTD CB Radio
No receive cobra 29 ltd classic
Hi and welcome to FixYa,
Initially, pls confirm that there is modulation (transmit audio). The reason I asked is if IC4 (TA7222P) is blown, then the radio would have no audio amplifier which would explain no receive audio. Additionally, the final and pre-final (TR15 & 15) gets is modulated TX+12 through D8 from T1 which in turn is the output of IC4 through C48.
Perhaps a schematic diagram may be of further help.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 18, 2008 | Cobra 29 LTD CB Radio
CB RADIO UNIDEN WASHINGTON PC-385 PCB
VR3 adjusts the transmit frequency. It's located near the center of the PC board close to the front panel. As this is a hit-or-miss operation, it would be wise to use a frequency counter when attempting it.
Aug 21, 2008 | Radio Communications
No Modulation!!
Most modulation problem could be traced to:
1. mic or the cable and/or the mic connector;
2. AMC (amplitude modulation control) - it's a single transistor that regulates modulation and occasionally has been known to clamped on the mic audio;
3. the AM/SSB switch - spraying with contact cleaner is a temporary remedy; and/or
4. audio amp - however if your receive audio is good, then this does not apply.
Hope this be of initial help/idea. Without a model number, I can't be more specific as to component(s) or PCB location but pls post back for any developments (or lack thereof) or should you need additional information.
Good luck and kindest regards.
Feb 09, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
Radio Communications Logo
324 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
