Question about Panasonic CT-34WX54 34" TV
Panasonic ct-34wx54. I cant remove the closed captions from the screen. When i go to the menu and try to shut it off the on and off modes are "grayed out" and cant be highlighted. Reset with power and action button wont work to reset it either. Please help. thanks.
    Problem Solver:
  • 9 Answers
Try pressing the volume down button on the T.V. and the info button on the remote. Do this for at least 5 seconds and it will reset the T.V.
Posted on Mar 18, 2011
I cannot turn off closed caption on screen. Panasonic Viera Plasma TH 42PV60A
hi,
To exit closed caption do the following.
1. Press the menu button and select CC and press OK button.
2. In CC menu select MODE and using right arrow or left arrow button select it OFF
3. Press OK button
4. Press menu button to exit menu option.
ok
Mar 10, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Black square comes on tv
hi,
in your tv the closed caption option is in on position. make it off o run out the black square.
to make the closed caption (cc) off. do the following.
1. press the menu button
2. select setup
3 go to closed caption (cc)
4. select closed caption mute (cc mute)
ok
Jan 27, 2011 | Panasonic CT-36D32 36" TV
Black box in middle of screen
enter in menu pressing the action bottom and turn off the close caption.
May 27, 2010 | Panasonic CT-34WX54 34" TV
Need to remove close caption on screen panasonic model no CT-20G85G
you need to go into your menu setting and turn ""cc" and any "text" to off position, gl, video-tek
Jun 08, 2009 | Televison & Video
Black square in center of screen - no "closed caption" solution
Here are the steps from the owner's manual:
1. Display MAIN MENU. Press ACTION key on remote.
2. Display SET UP TV screen. Use arrow keys to select TV icon and press SET key.
3. Display CAPTION screen. Use arrow keys to select CAPTION and press SET.
4. Select CAPTION MODE. Use arrow keys to select CAPTION MODE. Press SET to cycle through caption settings until it says OFF.
5. Press ACTION key three times to return to normal screen.
You can download the manual from Panasonic here if you need a copy.
Apr 03, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
Closed Captioning no longer works
check for the knub OSD on your remote to press it or at the menu select on screen display on
Apr 20, 2007 | Panasonic CT-27SF25 27" TV
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
Sep 27, 2006 | Panasonic CT-34WX54 34" TV
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Panasonic CT-34WX54 34" TV Logo
105 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
