My wysius plasma writes up none supported format when i put my ps3 through the dvi input using a dvi to hdmi adapter how do i solve this?
If u got a remote with v format keep pressing the button until u get a pix .for some reason it only works on 756 lines.
Posted on Jul 09, 2013
  • 23 Answers
SOURCE: HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Posted on Feb 17, 2009
  • 124 Answers
SOURCE: I HAVE A 42 ILO PLASMA TV WHEN I TRY TO USE THE
Set the DVR to send signal from the HDMI output.
Posted on Feb 21, 2009
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Posted on Apr 29, 2009
SOURCE: When I connect HDMI from a Time Warner DVR to my
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Posted on Dec 03, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-46PZ85U Plasma TV
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Posted on Jan 27, 2010
How do I convert an HD tv that doesn't have HDMI to be able to use this format?
There are adapters that can covert the HDMI signal to a DVI plug, but at a price. DVI does not handle audio as does HDMI. Most devices that have HDMI outputs will not parallel the audio to allow you to use adapter plus audio cables. You have most likely come upon this issue of obsolescence in you current device.
Oct 22, 2015 | Zenith Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do I set my Dell laptop to Samsung TV using HDMI
If you have a HDMI output on your laptop, then you should be able to plug a HDMI cable into a HDMI input on your T.V then change your input source on the t.v. If you don't have a HDMI output on your laptop then you should be able to use a DVI cable as long as your t.v has a DVI input, they also make a DVI to HDMI adapters, but keep in mind that DVI cables/adapters do not support audio.
Jun 25, 2011 | Samsung Televison & Video
What cable do i need to connect my laptop to my Sanyo DP50740?
Hello jaygee7414,
Sanyo DP50747 not support for D sub conection (PC in).
To connect PC in, you can use DVI or HDMI input.
Some Laptops already have HDMI or DVI out put. Like HP mini, sony vaio.
Or you can use s-video input.
Thanks.
Mar 21, 2011 | Sanyo DP50747 50 in. Plasma TV
I have no problems by connecting my PC/HDMI to Hp2025 DVi input using a HDMI to DVI adapter from PC/HDMI outlet together with a DVI-D (single link) from the adapter to the DVI input on hp2025. My...
talk to your adapter maker, (hdmi)??? and Grundig?
adaptor is not from HP so , how can HP help here?
my guess, is the Grundig does not support this device
ask Grundig? this? but tell them what adapter it is, first.
full name and model, and source, and then there is hope.
or find a video car that supports HDMI direct.?
what is Hp2025, HP says its a printer.
what is it, you imply its a PC, what PC, desktop it seems
even google can un tangle what is a 2025
just a clue.
post like this.
what do you have now, name the parts. all of them. (on topic)
full names, and full model numbers
Operating system used. (windows? linux?)
the state what dont work (HDMI on Grundig, bla bla.)
watch google , go batty
https://www.google.com/#q=Hp2025
the HP has a service tag with full model on it
what might that be?
May 10, 2017 | HP 2025 20.1" Flat Panel LCD Monitor
Hp plasma ID5226N can get external audio input when in HDMI 2. I have a DVI to HDMI cable from my computer to TV, & manual says to hook the audio to the input jacks, but no sound comes out. I can use...
DVI cables are usually HDMI compatible. The downside is that DVI usually doesn't carry any audio. Your computer may need a specific audio card to transmit audio/video data from your DVI output to the HDMI input on the TV. You can find one at your local computer store and ask if it is compatible with your computer
I hope this helps...good luck
Jun 23, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
Nov 09, 2009 | Gateway GTW-P42M303 42 in. Plasma...
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Thanks
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hook up
Yes, you can! But not straight out of the box. You need to purchase a DVI to HDMI cable adapter. It will convert it so your tv can use it. Here is a link to some:
http://www.connectworld.net/syscon/dvi-to-hdmi-adapters.html
Hope this helps! Please rate me!
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
