Question about Bosch 18 in. SRS43C02 Classixx Slim-Line Built-in Dishwasher
Water in the dishwasher model Bosch srs 3012 at the end of the program remains a certain amount of water in the machine and the glassware is not washed enough
  • Bosch Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Posted on Mar 18, 2011
Bosch SGI4345AU/17 shows 2H on the display, it does not seem to matter which program is selected, the unit runs continually. It does not heat the water or finish any cycle. The washing tablet covers the...
The Control unit on your Bosch has a burnt out heat circuit. Just about every dishwasher has a number of "thermal holds" during the wash and rinse cycles in which the controller waits for the water to be heated to a specific temperature. Most dishwashers check for a temperature rise over a certain amount of time and will shut down if this increase is not seen, however, Bosch does not employ this secondary check and the unit will run for as long as you allow.
The Control Unit on your dishwasher will need to be replaced. Being as Bosch is extremely properitary on their parts sells, it is best to actually talk to a parts supplier directly in order to ensure you are getting the correct controller. It is very important that the replacement controller is for your model #, including the /17 designation at the end. A xxxxxxUC/12 controller will not work on your model.
The Control Unit is found in one of 2 places; 1) behind the Control Panel, or 2) at the lower right hand side of the unit towards the rear. Both are relatively easy to replace.
Apr 16, 2011 | Bosch Dishwashers
My Bosch dishwasher is streaking the glassware, inside of the dishwasher and plastic utensils for the past couple of months. What is wrong?
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 14, 2011 | Bosch Dishwashers
My recently installed SHE4AM Bosch dishwasher makes my glassware cloudy using Cascade liquid detergent and Jet Dry
you have to make sure the water temp going into the machine is correct. let the water run for about 2-3mins then start the machine.
Feb 24, 2010 | Dishwashers
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Glassware is cloudy
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Nov 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Sep 30, 2009 | Bosch Dishwashers
Bosch dishwasher she58c leaves all my glasses cloudy
using to much soap will cause this problem.
If the unit can not get all the soap out on the rinse cycle, it will leave residue on the glasses.
ALSO:
1)Make sure you are using rinse-aid!!!!!
2) turn your sink water on before you turn the d/w on. That way the water is already hot when it goes in.
Sep 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Top Rack of Bosch SHU43 is not cleaning the glasses.
I was having the same problem, as well as others. I took out the filter at the bottom and cleaned it thoroughly. I think it was spraying old food remains onto the clean dishes. I would never recommend this dishwasher to anyone. I can't believe it is top rated.
Jul 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Not coming clean
Hi, Are you using Jet Dry Rinse Agent? It is very important to keep the washer supplied with this stuff. Otherwise, glassware will come out with a cloudy film and water spots. If you are using it, perhaps it is not being dispensed by the machine. I am having this trouble now, but my machine is about 10 years old, and has always turned out beautiful glassware unless it ran out of Jet Dry. Now, there seems to be a problem in my machine not dispensing it, and I was searching for a solution when I came across your posting. Baxterdog
Dec 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 18 in. SRS43C02 Classixx Slim-Line Built-in Dishwasher Logo
194 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
