Question about Adtran 908e (4240908L1)
Have a t1 (d4, ami, Immediate start) connected to T1 0/3 is T02. When I call from the 908e across the T1 i just get dial tone back. The channel is off-hook, but on the pbx it is connected to it is showing dialing like it is waiting for digits from the 908e. I have pasted the relevant config. So when I dial 195 or 196 I just hear dialtone back. interface t1 0/3 framing d4 coding ami tdm-group 1 timeslots 1-24 speed 64 no shutdown voice trunk T02 type t1-rbs supervision immediate role network description "T1 to Maxxar" resource-selection linear ascending connect t1 0/3 tdm-group 1 vad rtp delay-mode adaptive voice grouped-trunk "T1 TO MAXXAR" no description trunk T02 accept 196 cost 0 accept 195 cost 0
  • jeffb665 Mar 16, 2011
    Changed the clocking to be external on the 908e and internal on the pbx. I still get dial tone when I dial 195 and 196
  • 3 Answers
Config t
rtp dtmf-relay inband
end
wr
Timing should always be
timing-source t1 0/1
Posted on Apr 13, 2011
  • 2,359 Answers
Check the Adtran box for external timing.
Posted on Mar 16, 2011
  • Vincent_G
    Vincent_G Mar 17, 2011
    Your carrier should provide timing.
    Your PBX's T1 card and Adtran timing should be both set to external.
How to adjust speed of 45 record a little slow on my Rowe Ami JBM 200
If there is a speed adjustment (refered to as "pitch") the there would be a small dial knob near the base of the tone arm.
Jun 02, 2016 | Audio Players & Recorders
Hey i have brought a second hand T1 and wanted to ask how to connect it correctly. I have sent Bose an email but no response. As may tell i'm not very technical with these kind of things. Firstly
Have you tried the MASTER output rather than the AUX output?
No one is going to write a 20-page owner's manual for you here.
And you DO need the owner's manual, apparently.
Try the right department at Bose. They DO answer emails. Or get one from a pro outlet like B&H or Sweetwater.
Mar 27, 2013 | Bose T1 ToneMatch Speaker PA System
Have a vodavi sts and i keep losing dial tone. Have to call my phone provider to reset lines in order for dial tone to get restored
The sts system does not work very well with digital communications. But did you try powering down the system and then restarting it? On some of the cases I have worked on the seem to help.
Mar 26, 2013 | Vodavi Starplus SP7314-08 Corded Phone
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
Will not dial out on landline in the tone mode but
There's something wrong with the base unit that connects to the phone line. It's not sending any audio to the phone line, which would explain why tone dialing doesn't work and people can't hear you. (Pulse dialing doesn't need the audio tones so it will still work.)
I've never run across one doing this before. The problem is almost certainly some electronic failure, and I doubt there's anything you can do other than replacing the thing. If this is still under any warranty it should be up to the manufacturer to repair or replace it. If you got this from VoIP service provider, contact their customer service department.
Feb 03, 2010 | Philips VOIP3212G/37
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Mitel SX-200 D PBX generic 1003 ACD- doesn't support ISDN.
You are not going to get the ANI information you need from the current configuration, the only way to get that information is thru the use of PRI.
Apr 08, 2009 | Mitel 9109-021-000 T1 Trunk Card (24...
Transform the fax from pulse to tone
ALTERNATIVELY FOR IMMEDIATE SOLUTION DIAL FIRST STAR(*) BUTTON AND DIAL . HAPPY FAXING OMNIPRESENT
Apr 10, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Adtran 908e (4240908L1) Logo
537 people viewed this question
Top Adtran Computers & Internet Experts
David Payne
David Payne
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
