Question about Dell E228WFP LCD Monitor
Dell e228wfp. Replaced ccfl's. White light for 2 seconds, then black. Green power light stays on. What should be my next step? Where can I find electrical specs for this monitor?
  • 11,361 Answers
Did yo verify that the new lamp solder connections are good, were the old lamps have any sign of wear such as blackened ends, or glow with pinkish color?
Board: http://lcdrepair.us/E228WFPc-inverter-power.html
How are the caps and DC voltage readings on the caps?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 17, 2011
Hello, I own a Dell LCD Monitor, when I boot up the computer the monitor stays black. I see the desktop image for half a second, but very faintly. The power light is solid green and remains so. I have...
The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the CCFL lamp is faulty. The CCFL lamp is a mini fluro lamp that provides the back lighting for the screen.
Jul 16, 2012 | Computers & Internet
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Dell E228WFP monitor cutting off, goes black
sysjrm, You need to visit YOUTUBE for video clips of "lcd monitor repair" to see if DIY project is what you can handle!!! After you "learn by seeing" some printed circuit "switch-mode-power-supply/inverter boards" having their "aluminum-can" electrolytic filter capacitors replaced and/or "thermally-intermittant" fractured solder-joints "resoldered" then you will be able to make decision on what to do about attempting a repair to your E228WFP! Note!!!! Make certain that your pc is not the cause of your BLACK SCREEN or BLACKnBLANK SCREEN problem/symptom by connecting a "known-good" monitor to your pc first!!! Please read the higher numbered(32 and up) pages in my fixya profile for more information on how to do the simple "flashlight test" for evaluating the state of shutdown that the switch-mode-supply may be in. Also read and follow the links you find in the profiles of "budmrtn" and "buddymc" that are very good ccfl back-lit lcd monitor technicians here on fixya. After you do your web research, remember to come back to this posting and do a comment and rating of this response if you feel that it has steered you in the right direction. Good luck with the repair. 12fixlouie
Jul 23, 2010 | Dell E228WFP LCD Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
Monitor turns on and screen comes up for about 1 second and then turns black. Green power light stays on and green
This will be a fault with the inverter section that powers the ccfl lights usually a transistor or an i.c replaced will cure the problem
Dec 22, 2009 | Compaq FP 7317 17" LCD Monitor
After 1 year, the monitor DELL E228WFP started to turn black
ainamat, Did you do the FLASHLIGHT TEST to evaluate the status of the "switch-mode-power-supply"??? Every owner of a lcd display with "cold-cathode-fluorescent-lamps" backlighting should know how to perform AND interpret the results!!!! It's a very easy test to do! FYI Your monitor has a backlighting sysem very similar to the NEW curlie-Q CFL energy-saving screw-in light bulbs!! They have an ELECTRONIC BALLAST (converter) circuit (ac to ac) to light them. Monitors have a INVERTER circuit (dc to ac) ballast circuit that generates 600-1100vac to light your CCFL's. If the SMPS detects a FAULT with itself or a circuit that it is supplying power to, It will go into SHUTDOWN mode to try and save the unit from a catastrophic, nonrecoverable failure. e.g. worst case sparks,smoke,fire!! Anna, you should READ and follow the threads in my other responses if you can get to my FIXYA profile pages under 12fixlouie, aka louie12fix and read what I have already written about the BLACK SCREEN of DEATH and YOUR options. If after doing some surfing of the net, you determine that this response has steered you to a solution to your BSOD problem, please rate this response on fixya. Good luck in your quest. 12fixlouie
Nov 13, 2009 | Dell E228WFP LCD Monitor
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Dell E228WFP LCD Monitor Logo
299 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
