Question about Bose Wave Radio II
I cannot turn my radio on via on/off button on clicker. I have to keep pressing CD and eventually it will come on. Also, I cannot immediately turn-on the radio. I have to first click CD then FM/AM. Please Help!
  • s2turbeville Mar 18, 2011
    Your solution worked except, the setup menu didn't display nor after pressing tune seven times until reset all -no was displayed. Pressing 2 just never displayed a confirm.
    My other problem is that the volume button is working efficiently. I have to click between the radio station or cd player menu to higher or lower the volume.
    Thanks for your help.
  • 2,574 Answers
Perform a system reset (Wave Radio II),your device will be restored to the original factory settings.
Here's How:
1.Press and hold Alarm time(menu) until setup menu is displayed.
2.Press tune > seven times until reset all -no is displayed.
3.Press Time - or Time + to Reset All -YES
4.Press 2 to confirm appears on the display,press Presets button 2.
5.Press Alarm time (menu) to exit.
Make sure that the power cord is fully plugged into an operating electrical outlet.
Posted on Mar 17, 2011
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Bought a clicker for my son's used 2003 Hyundai Tiburon (base) we just purchased. He keeps the clicker, I went to open the door with my key, and the car went into crazy mode. I put the key in th
It happens a lot for the Tiburon apparently....what you have to do is put the key in the ignition whilst the horn is going nuts, turn the key to the "on" position and wait a minute or so for the horn to stop blowing. Then press the "unlock" button on the fob until you see the turn signals flash. try turning the key over and see if it will start up. If it doesn't, try again, same thing only turn the key all the way off and try starting as normal again. I can't remember if it's the "unlock" or "lock" button you're supposed to press, but one of them does it. Test it while in the car and see if it locks when you hit lock on the fob.....oh, and also make sure all the doors are shut while you are doing this. It recalibrates the fob to the car's computer and resets your security system and keyless entry.
Jan 11, 2013 | 2003 Hyundai Tiburon
I have a lumina 2000 and i need to unlock my audio system
GM DELCO THEFTLOCK RADIO UNLOCK CODE:
1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down.
2. After doing step one and writing down the code, immediately press
the
AM/FM button to get the last 3 of the 6 numbers you'll need, and write
'em down. (if you wait too long between steps 1 and 2 and the LOC code
displays again, just start over).
3. Call this number, it's a prerecorded message, so don't worry about
having to talk to anyone...1-800-537-5140. The voice will ask if
you're
calling for Chevy, Pontiac, Cadillac, etc... When you here him tell
you
to press "2" for Pontiac, press 206010 and hit the # key. He'll ask
you
for the 6 digit code that you've written down. Enter that and press
the
* key. He will then give you a code, and the option to get additional
digit codes, but one should be sufficient.
4. Follow the normal procedure in your owners manual for unlocking the
radio with your new code...press the hour set button on your radio
until
you get the first two numbers of the code, then press the minute set
button until you've entered the last two numbers. Immediately press
the
AM/FM button once the correct code is entered and the code SEC or
"secured" will be displayed on the display screen. Now, just turn the
radio on, and your ready to roll.
There is an additional step you can take to remove all codes from the
radio and start from scratch by entering your own personalized 4 digit
code so that it won't get you in a pickle again! Just repeat step 4
and
you should get a display screen that reads ---. This means the code is
out, and you can now program your own code. Of course, once you
receive
the 4 digit code from the GM recorded message, just keep it in a safe
place, because you can use that same code again and again should you
have any more problems with it in the future. Good luck, and yes, it
does work.
__________________
Sep 08, 2010 | 2000 Chevrolet Impala
Hello, How can I load 6 cds into the audio system of my 2007 honda accord? I do not have the owners manual, kindly assist. Thanks.
Look on the face of the radio for the Load button. Turn on the ignition and then change it to CD by pressing the CD button. Stick a CD in the slot and then press Load. Wait for the CD to load. Now stick another CD in the slot and press Load. keep doing this until all 6 are loaded.
Aug 17, 2010 | 2007 Honda Accord Sedan
I have a 1265-267 opener and I accidentally deprogrammed the automatic opener clicker. It still will open when I push "hardwired" button inside the garage, but won't open with the clicker. How do I...
On the rear of the motor unit near where all those white wires go you will find the smart/learn button. Press and hold the button on your clicker while you press and immediately release the smart/learn button. Should do the trick.
Dec 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Locked radio and cd player
the
you're
you
you
the
until
the
and
receive
does work.
Sep 08, 2008 | 1998 Buick Park Avenue
I have a 2000 Honda Accord with a factory installed alarm. When I press the button on the clicker it won't disable it. The light on the clicker lights up and the battery is fine. I've tried manually...
When my alarm goes off, it usually happens when someone sticks their hand in the window to unlock the door. In order to turn off the alarm I close whichever door the person opened back, and unlock the door from the driver's side door. This usually turns the alarm off.
Aug 09, 2008 | 1998 Honda Accord
Not being able to access my aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Sep 22, 2007 | Kenwood KDC-135 CD Player
I have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Aug 30, 2007 | Pioneer DEH-P3000 CD Player
Bose Wave Radio II Logo
181 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
