Question about Philips (DBMMS171) Computer Speakers
There is a remote with two male plugs one connects to the aux in speaker base and the other to the audio source ... The wire had connection problems in other words you had to position them just right for sound to come out. I cut off the rubber protective casing and twisted the wires I got up to look for tape because I let it sit and that seemed to fix the problem the cords were tangled so I unplugged them to untangle reconnected them and can't get any sound to come out at all now hopefully that makes sense thanks for any input
SFroese
  • 141 Answers
SOURCE: No audio is coming through my speakers
If the receiver is actually powering up but you are getting no sound, there are few basic things to check.
Check the audio connections on the back (speakers AND inputs) to make sure they are tight at both ends and undamaged. Go into the setup screen for the DVD player and make sure the audio settings are set for PCM output and that you are using a digital or optical audio cable. Then make sure you have the correct function selected on the receiver to match the inputs. If the receiver has a speaker test function, use it to see if there is any output from the speakers. Finally, make sure the volume is turned up and the mute button is off.
Otherwise, the amplifier may be faulty
Posted on Sep 07, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Posted on Jan 28, 2009
  • 105 Answers
SOURCE: No sound via TV when PC connected
1. Ensure the TV is set to "home" mode in the user menu. If set to "Shop" it will not retain audio settings change
2. verify that the Audio out from the PC is working. Use a set of headphones just to verify
3. Triple check that you have the audio input assigned to the correct HDMI input
4. after doing these if it still doesn't work, I would suspect the Software update had a side affect that phillips is not aware of. Since this function would probably be missed by Phillips software testers, it is highly likely that this is possible. Contact phillips and let them troubleshoot the problem with you. Let them know it happed after you did the update also and let them know that you have verified the audio out from the PC.
Posted on May 22, 2009
  • 336 Answers
SOURCE: Speaker wire problem
Yes you can splice the ends onto the existing wires, but first make sure the ends are labeled + or - and make sure you hook the other ends to the speakers the correct way. Before you cut the connectors off of the speaker wires mark one of each of the pairs of the wires with tape, on each side of where you cut it so you can match the wires back up. Are the pre-wired, wires labeled + and -? or red and black? Or one of each pair is a different color wire ie silver and copper? If they aren't labeled its going to be hard to get the correct polarity (+ and -) for each speaker. I hope this helps post back if you have any problems.
Posted on Aug 19, 2009
  • 1779 Answers
SOURCE: I am adding solderless phono plugs to one end of
# 1 - You don't put phono plugs or jacks on to the speaker leads. You must have audio output jacks on your set in order to utilize surround sound. The only other way is if your using a cable box or vrc that has the audio output jacks. The way you just mentioned is the fastest way to blow your audio output ic's in the set.
Posted on Nov 24, 2009
Audio is not working
Is audio out on all sources? Check mute button on remote. Check audio in tv menu. connect audio out of tv to external amp. Like the aux in of your stereo receiver. If you have sound there then next remove and test speakers. touch wires of speaker to a aa battery.Be sure wies are disconnected from main board. Speaker make no sound then replace them . If speakers pop then replace main board. or board that has audio amp ic on it.
Jan 06, 2014 | Seiki SC323FI 32"lcd...
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
Hi I just bought a brand new 2010 Ford Fiesta Zetec and I am having problems with the ipod connection via the usb, It all displays correctly, it shows the name of the song and how long the song has been...
You need an AUX cable in addition to the iPod USB cable. Use both cables, and you will get sound :)
The AUX looks like this: http://www.oriongadgets.com/images/3.5mm-audio-extender-male-to-male-1.jpg
Jan 06, 2011 | Car Audio & Video
How do i connect an aux cord to my head unit
You can go to radio shack and grab a 3.5mm to 3.5mm cable. make sure that is male -to - male. Some decks are equipped with an AUX IN in the front and some in the back and then some have both. This wire will resemble the same input end of an earphone plug. Once you have your device plugged in then just press the SRC button on your deck till it says AUX, AUX IN, or Audio. Let me know if this helps
May 20, 2010 | Pioneer DEH-P6800MP CD Player
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
I just bought some speakers and a receiver, cd player no instructions, how do i connect it myself
- Use a cinch- cable (red&white) to connect the cd player to the input (often called CD or AUX) of the receiver
- Use standard speaker cable (two copper wires per wire) to connect each speaker to one speaker-output on the receiver
- Plug in the power cables
- Select the right input (or source) on the receiver
- Voila! Press play on the cd player and sound should come out!
Oct 08, 2009 | Audio Players & Recorders
I have F&D home theatre i want to connect it to laptop
go to radio shack or walmart . get a cable that has an 1/8th inch stereo plug on one end and two (male) rca plugs on the other end.
make sure your volume is not all the way up on either the computer or the stereo.
plug the 1/8 inch plug into your "speaker or headphone" jack on the laptop.
plug the red and white (male) rca plugs into the auxilary or cd "IN" on the home theatre.
Power up the stereo, make your source on the home theatre the Auxilary or CD, whichever you used to plug the RCA's into.
now you should hear anything from the laptop through the home theatre.
Regards..
Apr 25, 2009 | Creative Labs Sound Blaster Live! 5.1...
How do I connect a mac audio output to a yamaha sound projector?
NO!!! get a 3.5 male TRS to stereo RCAs to either the Aux input on the amp or the audio portion of the front A/V Aux. the audio jacks will be red and white.
Dec 04, 2008 | Yamaha Digital Sound Projector Home...
Receiving tv analog audio.
Based on the description provided, you seem to be on the right track.
Be sure to select the appropriate "source" on the receiver using the remote (or front panel). The AV connection on the back of the receiver is typically labeled (i.e. Video 1, AUX, VCR... or similar). If there's only one unlabeled input, choose something that looks like "AUX IN" from the menu.
Also, make sure that you connected the cables to the TV via the "Audio Out", not the "Audio In" ports.
If these are too obvious and you have already done this, please provide additional information.
May 14, 2008 | Onkyo HT-SR800 System
Trying to sort aux-in
as you do not mention the model I have to guess that your player has a aux-in on phono (or RCA) jack. If you want to plug the iPod just buy a "Twin phono to 3.5mm stereo jack cable".
You can find in many superstores or Maplin.
Mar 30, 2008 | Audio Players & Recorders
Philips (DBMMS171) Computer Speakers Logo
26 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
