Question about Zodiac Baracuda Zippy Pool Cleaner
MY Baracuda can be prompted manually to start by pulling and shaking - it runs varying times and stops - sometimes only a few minutes - my filters and baskets are clean? help please!
  • 640 Answers
Check your Star Control settings to make sure that you are getting adequate pressure. If you get a blue or black reading, you are not getting adequate flow and need to increase (aim for the yellow zone). You will also want to make sure that you don't have any obstructions that are preventing movement (in the mouth of the cleaner or hose). If these are not the cause, I would make sure that you have assembled the cleaner correctly. Here is a copy of the users manual for these pool cleaners.
http://www.baracuda.com/resources/manuals/W83309.pdf
Posted on May 11, 2011
2004 durango shakes at 45
What was serviced a few weeks back? Sounds like it needs a tune-up @ least to start - spark plugs, plug wires.
At 103K miles I'd also replace the fuel filter, air filter, PCV valve. And if you look in the Owner's Manual it should have a maintenance schedule for other items that may need attention.
GL,
TD
Mar 14, 2014 | 2004 Dodge Durango
I have replaced the diaphragm on my Classic. I have even replaced the filter sand. There are no apparent tears in the pipes, yet the cleaner runs for a few minutes and then stops dead, not pulsating. The...
Use Pool Pulse to ensure proper flow. It could feel ok on your hand, but you need very precise pressure to power these pool cleaners. If you are not familiar with how to use the Pool Pulse feature, take a look at the users manual below. They have a step by step guide to this feature.
http://www.baracuda.com/resources/manuals/G4W83408.pdf
Oct 20, 2010 | Zodiac Baracuda G3 Automatic In Ground...
MY POOL CLEANER WILL RUN FOR A FEW MINUTES, THEN STOP. SO METIMES IF I SHAKE THE HOSE IT WILL START AGAIN. ANY ANSWERS?
Hi , most pool cleaners run by the force of the sucked up water moving gears inside the cleaner .. if yours is this way, then any blockage in the cleaner or in the hose attached would restrict the flow and keep the cleaner from moving.
Apr 30, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
The cleaner will run 1-2 minutes then stop. I can shake the hose & it will start again for another minute or 2. Everything looks to be in place and working. Any suggestions would be appreicated.
First, remove and check diaphragm for cuts or rips. If ok, check hoses for leaks. You can do this by holding hoses one at a time above water level while cleaner is running(or supposed to be running). If there is a leak you will hear it sucking in air. Make sure filter is ok. If a cartridge filter, remove cartridge and run without it in. If cleaner works ok without cartridge either acid wash or replace cartridge.
Jan 23, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Nissan 300ZX shakes
check items in your fuel lines first, filter, pressure regulator....could be anything running down that line, don't waste your money on a fuel pump until it's the last option
Jun 03, 2009 | 1990 Nissan 300ZX
2004 Chevy Malibu won't start and shakes when stopped at light
The next time it starts shaking and acting up its the time to have a fuel pressure test, or maybe if you can't remember the last time the fuel filter been chg. do that and see if it dosent run any better. Could be filter getting cloged up, or maybe pump getting weak and dosent show up until its run a while and has got warm.
Mar 29, 2009 | 2004 Chevrolet Malibu
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Apr 23, 2007 | Kenmore 54351 Dehumidifier
Zodiac Baracuda Zippy Pool Cleaner Logo
298 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
