Question about SIM2 DOMINO D80 DLP Projector
How do you reset the lamp timer on a Sim2 Domino 60.
  • 442 Answers
I would need to know the serial number of the unit.
You need to press 2 buttons on the remote then enter a five digit number to enter the service menu to reset the lamp counter.
Posted on Mar 17, 2011
How to reset lamp hours on Sim 2 Domino 18
I am not familiar with your brand in particular but they are all pretty much the same. In the menu under settings you should be able to scroll to lamp settings. Under that category or something like that will be where you can reset the hours.
May 20, 2014 | SIM2 Office Equipment & Supplies
My DLP projector SIM2 DOMINO D35 is turned on and works normally BUT picture is absent on all of inputs (projector shows NO SIGNAL, green indicators is ON). Sources of signal and cables are in order. What...
It is possible that the last time this was connected there must have been an higher input applied than is recommeded so that the input PRE_AMPS were loaded to fail.
You need to check with an signal trace on the input to find if an OP-AMP has failed or the LOGIC switching IC had failed.
Need to test using a signal tester and meter.
Jul 14, 2011 | SIM2 DOMINO D35 DLP Projector
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Power LED stays red - does not want to turn on
    hi maybe I am very late for this, but do you still have the SIM2 D10?
    I need some part if of course you have it and it still broken.
    Thank you for your reply
    Jan 20, 2010 | SIM2 Domino D10 Home Theater Projector...
    Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
    the number of blinks determine the problem:
    Environment Over Temperature- 1 long blink / 1 short blink
    DMD Over Temperature- 1 long blink / 2 short blinks
    Lamp Over Temperature- 1 long blink / 3 short blinks
    Fan1 Locked- 1 long blink / 4 short blinks
    Fan2 Locked- 2 long blinks / 2 short blinks
    Fan3 Locked- 2 long blinks / 3 short blinks
    Fan4 Locked- 2 long blinks / 4 short blinks
    DMD Initial Fail- 3 long blinks / 1 short blink
    Lamp Initial Fail- 3 long blinks / 2 short blinks
    Ballast UART Error- 3 long blinks / 3 short blinks
    Temperature Sensor Fail- 3 long blinks / 4 short blinks
    Inter Lock Open- 4 long blinks / 1 short blink
    any of these will result in lamp off and shutdown.
    Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
    How do i reset the lamp meter after i change the lamp
    Press and hold "Volume Down" button on TV front and press "Play/Split" button on TV remote control for 6 seconds, Lamp Timer Reset message will come in screen.
    Aug 07, 2009 | Panasonic PT-60LC14 60" Rear Projection...
    Replacing the lamp in SIM2 ht-200
    OPen top case with four screws, two on back of the unit and two on the bottom. Remove six screws on lamp cooling fan, unpluf lamp (Brown Connector) unscrew lamp.
    May 28, 2008 | SIM2 HT300 Multimedia Projector
    Sim2 domino 20
    Hi there
    I checked the manual of your Sim2 , but they don't even mention the lamp in there.
    You already have the front cover off , check if you can see any small screw around the lamp housing. They normally attach the lamp's housing with tiny screws to the rest of the unit.
    Apr 24, 2008 | SIM2 Domino 20 Multimedia Projector
    SIM2 DOMINO D80 DLP Projector Logo
    691 people viewed this question
    Top SIM2 Office Equipment & Supplies Experts
    k24674
    jasbo
    jasbo
    Are you a SIM2 Office Equipment and Supply Expert? Answer questions, earn points and help others
