Question about McCulloch Garden
The manual oiler on my mac 110 does not work. The parts are available. What is the procedure for replacing the manual oiler parts which are located in the oil tank.
  • 3 more comments
  • billdiehl60 Mar 19, 2011
    I have not found anything at lawn and gardens. I was hoping for a short step by step procedure.
  • billdiehl60 Mar 20, 2011
    Dear sir
    Dear Sir
    None of the suggested sites were usefull (one sight was blocked by my computer security system as being potentially dangerous to my computer). Suggesting a web site to look at is not what I asked of the fixya experts. I asked for the procedure. If nobody knows of the procedure then I shall take the chance of doing the replacement without a sure way of doing the job.
  • billdiehl60 Mar 21, 2011
    I figured out how to remove the manual oiler so no more research is needed. I will accept your last post.
  • billdiehl60 Mar 23, 2011
    This is the web site my computers security system warns me not to open. In the past I have had problems when I ignored the warning. I will not go there.
    Anyway, as I informed you before, I have figured out how to get the oiler out and clicked the accept button to end the session. Have a nice day.
  • 7,733 Answers
Give a try at Lawn and Garden Manuals.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Mar 17, 2011
My McCullough chainsaw series 3200 is leaking oil, all the oil drained out. i need a manual.
Operator Manuals for McCulloch are difficult to find and will not help with this problem unless you want a repair facility. You can try here:
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
You provided no model number; this one was given in a 3200 fuel problem I answered earlier. An IPL for the model you provided follows (this is actually a 3214, I have never found a 3200):
http://www.ordertree.com/modelinfo/MCC/11-600032-32-Mac-3214-06%2F93-IPL-211229/139.11-600032-32-Mac-3214-06%2F93-IPL-211229.1.59.1.html
It is the only 600032-32 here:
McCulloch IPLs (all)
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There is a less detailed print here:
Chainsaws 32cc-35cc
On this block of saws the oil pump is under the flywheel and there are many hoses. Please use the IPL to identify and locate oiler parts. I hope you find a burst hose. There are oil pump repair kits listed. Unless the pump has an obvious crack or hole I would not attempt to change it until I had exhausted all other possibilities.
This works for older MCs but MTD (this one) saws often deviate from the explanation. It will give you a little guidance if you try to locate a different IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
I know it is not plugged but this may also be helpful.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
These are very difficult to work on, most saw shops will not attempt a repair. I hope the chainsaw Gods smile on your undertaking. Good Luck. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa HTH
Lou
Mar 27, 2010 | McCulloch Garden
Oil pouring out of mac3516,chain oiler
You have my condolences.
Your saw is here, which one?
Chainsaws 32cc-35cc-38cc Anti-Vibe
I chose "22-600035-18" as an example , it follows (more detailed print - may not be your saw):
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
Oil System Plugged:
Lou
Mar 22, 2010 | McCulloch Garden
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Pro Petrol chainsaw: no oil getting to the chain. Definitely blocked somewhere and I'm not sure of the procedure to unblock it.
Try this;
It should help you find an IPL with oil system detail (may be on multiple pages). Oiler components and part numbers can be found if you need parts. Mac most often have an impulse driven oiler. Hose failure or disconnect common cause of this malfunction.
If not successful post back with the numbers you find and I will gladly assist you. HTH
Lou
Jan 19, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How do I fix a converence problem?
Hi.
First try using Autofocus. If there is a convergence problem this won't fix the problem.
Try using the convergence alignment procedure from service manual.
Here the procedure that works on most Hitachi rear projection.
Here the grid with convergence problem
If the procedure does not work, then the two STK392-110 on convergence board must be replaced.
Before replacing the ICs you can test the pico fuses located on convergence boards. Simply read ohms to test if they have continuity.
Better also testing components on convergence board like resistors located at the base of STKs.
After removing the old STK, the new ones must be re-soldered using cooling paste.
Price for single IC can is about $8/$20. I think
STK392-110 on this model can be better replaced with STK392-150. I suggest contacting the seller on this.
The service manual is available here.
Jan 12, 2010 | Hitachi 50SBX78B 50" Rear Projection...
My 110 model chain saw sucks chain oil back into the piston cylinder. When I remove the spark plug and pull the cord it spews out red chain oil. What is the remedy
Did you adjust the oiler? To far CW might cause this. The automatic oiler is driven by an impulse line from the crankcase. If the piston assembly is to deep or has failed there is a direct line into the crankcase.
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Mac 110” 600016C may also be a _# instead of letter 600016_03) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Mac 110” IPL number = 11-600016C). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Click “11-600016Letter or YourDashNumber”
Every Oil Pump will eventually cross to
Entire pump assembly:
219989 Kit Pump Assy (Oil) $9.29
O-ring
110653 O Ring $0.75
I have found McCulloch parts here I can get no where else and they are reasonable.
You can download a complete parts breakdown for your saw here using the IPL constructed above:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
Please see if the parts you need are available here. They were not when I ordered them but it is a nice way to say thanks for providing the IPL. I hope you find this helpful.
Lou
Dec 18, 2009 | McCulloch Garden
Mcculloch eager ****** no oil going to chain
The oiler pumps on Macs are the usual suspect, try this:
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Build an IPL number like this:
McCulloch Manual
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
If you can not find parts please repost with the IPL number and I will share my secret Mac parts source.
Lou
Dec 03, 2009 | Drills
I have a McCulloch MAC 110, Model 600016C which
The IPL (exploded parts list) for your saw can be found here:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600016C_MAC_110_01_77_to_02_83_IPL_95807_R2.pdf
Page 6 item 21.
You have to remove the engine to access it.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
There is some discussion about the proceedure in the McCulloch thread. Its a good little saw. I'm awaiting oiler parts on mine. HTH
Lou
Oct 03, 2009 | Garden
McCulloch mac 10: manual oil pumper not working. Front cover removed and oil tank & filter screen cleaned. Orifice clear. Is there a pump part that can be replaced? Fredm@roadworksauto.com
I have a Mac 110. I ordered the parts needed for the manual and automatic oilers to repair it last night. I can now safely share my source with you. LOL
M&D Mower
http://www.m-and-d.com/unlisted.html
Part of the order process shows an IPL. I recommend you save as many of the drawings as possible.
Aug 26, 2009 | McCulloch Garden
McCulloch Mac 120 oiler
I think the problem is the funny rubber-hose-connection of the oil tank to the oil pump. It looks quite flimsy to me... But if you want I can have a look how this screw is adjusted...Bye, also tom
Jun 18, 2009 | Standard Oregon Chainsaw Chain For...
Garden Logo
96 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
