Hi, my sony is giving me a oversized picture on the satellite channel and the video game systems. I lose about 3" on the top and bottom of the pictures. I tried using the normal and zoom functions in the menu. I tried plugging into other inputs on the tv. I tried a power reset also. I can't read the scores on games or sometime see the full name of a tv show when it uses the full screen, same on the video games. Some tv channels look very grainy like they are zoomed in way to far. I just want to see if there is a fix for this or just a maintence issue. Thanks
  • 44 Answers
Have you tried changing the HD resolution settings on the TV? If that doesn't work, then it just might be a maintenance issue.
Posted on Mar 16, 2011
KP-46WT500 46 in. Rear Projection HDTV-Ready Television: I'm losing the top and bottom of my picture. The ...
Make sure you try two different sources to the tv, such as a cable box, dvd player and/or gaming system. If you have issues with all sources then it is for sure the tv and there should be a format option. However if it is only one source that the issue is with the issue is of course the source.
May 07, 2010 | Sony KP-46WT500 46" Rear Projection...
Screen display mode
Because the broadcaster is giving you the bars at top and bottom there is nothing you can do except use the different aspect or screen formats that are on your TV. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Televison & Video
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Turn on goes blue then turns off
The most common reason for a TV to display a blue screen with no picture is because the source device has not been set to the proper mode.
If you are using a cable or satellite set-top box, ensure that it is turned on and set to an active station. If the set-top box is connected to the television using a coaxial cable, then the television should be set to Channel 3 or 4 to receive the signal.
If you have are using a VCR that is turned on, but not playing a tape and not tuned to a receivable channel, then a blue screen will be displayed on the TV. To resolve this, turn off the VCR or tune it to a receivable channel. If a cable or satellite set-top box is connected to the VCR using a coaxial cable, then the VCR should normally be set to Channel 3 or 4 to receive the signal.
If the blue screen is not because of a connected VCR or set-top box, the TV may require service.
Sep 22, 2009 | Sony KP-57WS500 57" Rear Projection...
Hi, Can you tell me how to do a reset on my playstation 3 back to the default, or factory setting?
yea. this is easy. first on the XMB go under "settings", "system settings", then towards the bottom it will say "restore default settings".
it will tell you everything it will restore then walk you through the rest of the process.
this will not delete any videos, music, pictures, save data utility, game data utility or friends/trophies.
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Picture is only black screen with white lines
Are the console and the TV both tuned to Channel 3 or Both to Channel 4. On the SNES there is a little switch on the bottom of the back labelled 3 on one side and 4 on the other.
May 31, 2009 | Nintendo Super NES Console
Multi player screen displayed side by side, i want one top, one bottom
its not your ps3 its the game, just go to options on the main screen or on the multipllayer menu and go to screen layout and change it to verticle from horizontal
May 17, 2009 | Sony PlayStation 3 40GB System
Need to install a PS2 to a cable box.
unhook the cable box from the tv and hook that cable into the ant in on the modulator and run the output of the modulator to the tv.set the modulator and tv on channel 3.you may have to turn off the cable box to play ps2.please give me a rating if this was helpful,if you need more help just ask
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
