Question about Mitsubishi WD-52725 52". Rear Projection HDTV
On WD 52725 when the lamp goes out, will there be any power at all running through the TV?
    Problem Solver:
  • 10 Answers
Yes, no pitcher or sound
Posted on Mar 16, 2011
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
Jan 06, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Had a power surge and now the lamp notification is on steadily
This is a common problem and usually shows up when power is interrupted. The capacitors in the micro, digital, and power supply have to be replaced. In my shop, we prefer to send the chassis to Mitsubishi and they repair it. Do you have a local authorized Mitsubishi service center near you?
May 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Jul 22, 2009 | Mitsubishi WD-52725 52". Rear Projection...
How to reset hours (4000) after replacing lamp
when you replace the lamp as soon as you power up the set it should automatically bring up the menu asking if you have replaced the lamp and would you like to resett the lamp hrs. Your problem is not with the lamp. its most likely the power pwb capacitors. You can get the repair kit at the following link with instructions.
http://servicemanuals.vstore.ca/
Sep 25, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
