Question about Black & Decker Steam Generator SG200 Iron
My steam iron emits loud screeching sound when in use and steam comes from the base
Philips manual
You should clean your Philips Steam Iron. Follow the video guide given below to clean your iron
Aug 16, 2014 | Irons
Swan steam iron
The iron has failed and is leaking steam where it shouldn't be leaking.
May 23, 2017 | Irons
Team international steam iron
Make sure the valve between the base and iron is open.
Nov 23, 2013 | Irons
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
I just purchased a used EuroPro Steamer model EO8020. After about 5 minutes of use on the steam setting, the base starts making a loud rattling sound. Doesn't sound healthy to me. Can you...
It's just normal to hear that because heat inside is generating and steamer is on it's way to be ready for use. Hot air is about to be release and so rattling sound occured.
Need not to worry about it, the steamer is new and functioning normally.
Good luck
Jun 25, 2011 | Euro-Pro Steam Generator EP8020 Iron
Swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
Sep 17, 2009 | Irons
Black & Decker Steam Generator SG200 Iron Logo
61 people viewed this question
Top Black & Decker Irons Experts
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
