Question about Sony Dvcam DSR-PDX10 DV Digital Camcorder
Sony pdx10 not being recognized by computer via firewire. Only says DV In. Don't believe it's the cable. Wondering if there is a setting I'm missing. I've been using a dsr 200 plug in with firewire and it works fine.
SOURCE: DSR-11 stopped outputting anything
I have almost the same problem!  Did you ever figure out what happened?  Here's what I had posted yesterday:
Tech Friends -
I recently got a non-sony tape stuck in my DSR-11 (bummer) and was forced to extricate it using the "my tape got stuck in the DSR - 11" article's method of removing the top cover and highest level of circuit board:
http://www.fixya.com/support/t178954-tape_stuck_inside
This worked for the tape removal, however, upon replacing the circuit board and cover, the deck no longer seems to be able to do anything with video or audio.  It still communicates with FCP via its firewire connection (ie FCP is able to control FF, rewind, play functions, etc), but it seems unable to read or write video.  Also, we use it as an A - D converter box between a Beta SP deck and thecomputer (actually, this is the deck's main function here).  Even when I switch it to the correct setting (video) and check to make sure that everything is plugged in correctly (trust me, I checked, it is), I get the "there is no video here" error message.
Also, after trouble shooting the drive for a little while, I pressed the "reset" button the the rear.  I'm not sure if that matters one way or the other.  I don't think it does (that just resets the time code, right?)
The question is, would this be a case of "fried firewire jack" such as it seems so many of us DSR - 11 owners have?  Could I have done any frying myself by not having myself properly grounded when opening the shell?  Is there anyone who knows the answer?  Help!  I can't digitize my video!
Comment by eltriunfo, posted on Sep 05, 2008 The Plot Thickens...
Okay, I've checked all of the FCP settings and played with the deck more and it's only confused me more.  I can now get it to not only be controlled by the computer, but actually print audio and video to mini dv tape.  Also, I can record from my Beta SP deck to miniDV tape in the deck (connected through the "video" input on the rear of the unit).  In other words, the deck seems to function perfectly doing everything except for converting analogue to digital passively.  The way we always did it before was by keeping the input switch on the face of the unit on "video" and log and capturing in FCP with it as a noncontrolable ntsc device.  This makes me understand it less.  It means to me that it is not a broken switch, it's not a broken firewire port, everything works perfectly EXCEPT for using the unit as an A-D converter.  What the dill-yo?  If anyone in the world could offer any insight as to what could be causing this I would greatly appreciate it!
Posted on Sep 05, 2008
mediarich
  • 188 Answers
SOURCE: Bad DV Out Port
There are settings like on pg 211 of your manual you might have to switch from analog out to DV out. I bet thats it. There are other options around pg 221 for USB output settings but I didn't see any conflict but it doesn't mean there won't be some.
Good Luck. Leave a comment if you need more info . Just in case here's where to get a copy of the manual: http://www.mannlib.cornell.edu/equipmentandrooms/upload/DSR-PDX10.pdf
Posted on Oct 04, 2008
SOURCE: dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Posted on Dec 01, 2008
  • 297 Answers
SOURCE: windows won't recognize my sony dcr-trv19
Need a 1394 firewire port and suitable software like Corel Videostudio. Then no problems. When no 1394 port thoes pci cards come cheap, $15 or so. Video studio retails about $100 I think, you can download a free limited 30 day trial from Corel. Please uninstaal that demo after 30 days with the same install programm otherwise deep ****.
Posted on Jun 05, 2009
SOURCE: DSR-45 DV connection to Mac Pro G5 Firewore
MAY BE PORT PROBLEM OF THE DSR45
Posted on Feb 06, 2010
USB Driver for dsr pdx10 for mac
You do not need drivers to get the footage from tape to a Mac. You do require a firewire cable and use iMovie or Final Cut to capture.
May 23, 2011 | Sony DSR-PDX10 DV Digital Camcorder
I have a mini DV SONY DCR-PC9E PAL camcorder and i need to copy my tapes on my WINDOWS 7 Ultimate 32bit. Don't Have the Driver, and my computer is not reading the USB cable connected from the Camera to the...
I believe this camera has a firewire/iLink connector.
Using a firewire cable will allow you to not only transfer videos, but will also let popular video editing software control your camera for ease of use!
As for the driver, your camera is specific to latin america.
You might try to download this program which is a licensed sony product, but will be in spanish. It may have drivers built in, which will allow your pc to properly recognize your device in other programs.
Feb 23, 2011 | Sony Handycam DCR-PC9E Mini DV Digital...
I am trying to connect my Sony DCR-TRV10E to my home computer via ilink-USB cable, but my computer does not recognize the Camcorder.... I guess this is due to missing drivers for Windows 7. Can anyone help...
USB and i.Link cables are not the same thing. What Sony call i.Link everyone else calls Firewire, DV or IEEE1394, and it is a different standard from USB with different connectors.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. If you are trying to use a USB cable for video download, then it won't work for this camera. The driver is not the problem, this model is not on the Sony list of cameras that will download video over USB.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading at THIS LINK You will need to select Windows as the operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many Mini-DV cameras.
Jan 02, 2011 | Sony Handycam DCR-TRV10 Mini DV Digital...
I have sony trv33 and windows 7 using firewire 1394 port and cable computer does not recognise camcorder when turned on
Your camera will not be recognized when you connect it via firewire. To transfer the video from your camera to your computer you will need a video editing program that is able to capture video from camcorders connected via firewire.
You can try Windows Movie Maker for Windows 7. Alternatively your can search through the internet to find a more advanced video editing software.
Regards,
nicolasiac
Feb 03, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
Sep 10, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
Sony DCR-TRV8 video transfer problems
The USB drive for Sony CAM you can download from Sony web but the USB will not allow you to transfer video from your CAM only for memory stick
However if you have firewire input on your Laptop, have you? normaly if you have firewire input on your laptop as soon as you connect your CAM it will detect automatic either with windown movies maker or with Nero
Sometime the firewire from CAM defect I repaired a few of them with this problem
Can you conect this CAM to another computer or try different cable ?
Or tell me exactly what input you have on your laptop such firewire input, PCMCIA slot
Cheers
Dec 04, 2008 | Sony Handycam DCR-TRV8 Mini DV Digital...
Bad DV Out Port
Oct 03, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Unable to tansfer video to computer using DV cable..
Pinnacle software will recognize the camera installed through a firewire cable once the camera is turned on. Windows movies software doesn't recognize DV cameras. You may be able to get capture to work if you go to Microsoft.com and download the Windows Media 9.0 Development Kit. I believe DV input is a capture option.
There has to be a 3rd party program installed to get it to recognize it.
Good luck on that.
Sep 20, 2007 | Canon ZR800 Mini DV Digital Camcorder
Firewire (i-link) computer does not recognize cam
as far as the camera not being recognized when using firewire, you have to use a genuine, original Sony i-link/firewire cable. for the longest time i couldn't figure out what was wrong with the camera. i tried two different cables and two different computers. finally i took it to a sony service center and had them check it out. when i went to pickup the camera they said there was no problem. i didn't believe them and asked to talk to the technician that worked on the camera. I told him to show me it worked and was recognized. He did indeed, but using a sony cable. when i gave him my cable to try, it didn't work. luckily they were nice enough to let me go without paying the $80 minimum charge for any work, including the diagnostic "plugging in sony cable" check. I then bought an overpriced sony firewire cable for $25 and everything works. Damn sony's proprietary **** (all the sony people i related this story to blamed the bad quality of the cables i had been using)
Sep 29, 2006 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Dvcam DSR-PDX10 DV Digital Camcorder Logo
6,101 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
