Question about Toshiba Computers & Internet
My laptop will not load Windows. I have tried to start it in safe mode, but it shuts down and restarts. Do you think that this is a hard drive issue.
    Scholar:
  • 59 Answers
Could be a few things, it could be a bad hard drive, it could be other faulty hardware, the windows installation could be messed up. First things first if you have any important data try and back it up. If it is a hard drive that is going bad you want to catch it in the early stages. The first thing to try would be to try a repair install of your OS, I'm assuming you have windows xp or vista. If you need help with doing a repair install or ways to backup your data post a comment on this question.
Posted on Aug 02, 2008
My del studio laptop doesn't shut down
You could have a corruption in the script or a process that won't stop. Try holding down on the power button until the screen goes dark and all lights go out. That is a hard shut down without saving settings. After it shuts down (finally) power it back up. Hit the F8 key on your keyboard the moment your machine goes to the black screen before it can load windows. That is the safe mode. Move the highlight up to safe mode or safe mode with networking and allow it to continue to boot up. Then, when it's completed the process and windows displays that it is in safe mode, do a normal restart. That should resolve the issue.
Oct 22, 2013 | Dell Studio 1737 Laptop
My hp laptoop restarted again and again always shows black screen and then system shut down and restart again
Try booting under safe mode if using windows xp:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013595&lc=en&cc=us&dlc=en
Windows 7 safe mode:
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
This sounds like it could be couple different issues - namely a corrupt driver or OS file, or a physical malfunction of the hard drive.
Apr 15, 2012 | Computers & Internet
When I load my Toshiba Satellite L305D-S3958 It loads up saying it didn't shut down successfully. I tried all the modes from safe mode, safe mode with networking, safe mode with command prompt, and Star...
I hope that you have a goood back-up of file. Getting blue screen error is a fatal OS problem. You need to re-install windows.You need to get the CD that came with your computer or the operating system disc you used to install the windows. Insert the disc on the CD-DVD drive and restart your computer. Watch for a Press any key to boot from CD or DVD... message. Installation will start. Good Luck!
Mar 14, 2011 | Toshiba Satellite L305D-S5938 Laptop
Computer turns on, no signal to lcd. Hard drive
The blue screen was caused by corrupted drivers or a virus that was corrupting the drivers. Have you tried starting the machine in SAFE mode? To do this press F8 while the computer is starting before Windows loads. You should get a menu with several SAFE mode choices. Select SAFE mode and continue. If the computer works fine at this point, I suggest downloading the following AVGFREE.exe, MALWAREBYTES.exe and SUPERANTISPYWARE.exe. Run these to absolutely eliminate any chance of a virus. Once done go to START, Run and type SFC/scannow. You’ll need to have your original CD’s handy. This will replace any corrupt drivers. Now, what to do if you can’t get into SAFE mode. The question then is anything showing on the screen? If nothing but you can hear the fans but no beep codes I suggest you take the laptop to a reputable repair person or check my website www.micromendllc.com. Good luck.
Mar 01, 2010 | Computers & Internet
UNMOUNTABLE______BOOT_____VOLUME ***Stop: 0 X
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
I have a Sony Vaio PCG-FRV26 series laptop that has just started shutting itself down and restarting after windows has been up for only a minute or two. I have taken the unit apart & cleaned everything...
The main drive (C) being too full is an indicator that's your problem. Windows reserves space on your drive called a 'swap' file. It effectively takes hard drive space and uses it in lieu of RAM if you don't have enough available RAM to run programs.
If the computer doesn't have enough hard drive space to create the swap file then it won't boot up, as it will interpret the lack of available space as a failure to install the file and then try to reboot.
Luckily it doesn't install one when you're in safe mode. Try going into safe mode and restoring some of your hard driver space, as well as performing a cleanup and defragmentation of your hard drive, and chances are it will boot up.
As an alternative you might think about getting an external hard drive and using that for any new programs/music/videos/etc.
Sep 04, 2009 | Sony Computers & Internet
HP530 shuts down within 15 seconds as it loads XP
Probabpy an XP problem, start XP in safe mode (press F8) as it is loading.
If it runs then it is probably a driver problem. Try restarting in the last good configuration. Keep posting until the problem is resolved.
Aug 17, 2009 | HP Computers & Internet
I had to restart my IBM Laptop by shutting down the power manually.now it will not re-start windows even in Safe mode.im getting a ECC Error sectors 53072284 - 53072411 Hard Disk Drive any help would be...
Sounds like a corrupted or damaged hard drive, if u can get to dos instead of safe mode try running one of these to commands to do a hard drive sector check and repair:
chkntfs - dos hard drive check
scandisk - windows hard drive check
Even if these fix the hard drive problem depending on what sector was damaged u may still need to reinstall windows though
Mar 29, 2009 | IBM ThinkPad R40 2722 Notebook
Shuts off at boot up screen?
Start the computer in safe mode (tap F8 immediately after turning it on until you see the option of how to boot)
If it successfully boots into windows, you have an issue with either driver conflicts and/or viruses. If it still restarts itself, you most likely have a hardware issue (bad hard drive, motherboard, etc)
Jun 24, 2008 | Acer Aspire 5000 Notebook
Computer shut down ..wont restart
what has happened is your hard drive as failed and that is why it shut down and then gave the unmountable boot volume. You could try repairing windows using your XP cd but it's a new hard drive i recon.
Oct 05, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
