Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have a RCa broadband modem from Comcast. I want to connect my computer Fax card to it. IS that ok? How do I do it? Just connecthe telephone cable from the port at the back of the computer to the RCA Modem?
    Problem Solver:
  • 14 Answers
Yes it is perfectly OK. Remember that a fax essentially works as a phone, so you would run a line from the RCA modem to your fax card, then from the fax card to your telephone. In this scenario you would have to accept your faxes manually though.
Posted on Mar 16, 2011
I have a Dell inspiron 537 sesktop pc and the lan adapter is not recognizing the ethernet lan connection. I reinstalled the drivers etc but it still show " not connected ". Is there anyway to...
To connect to the Internet, certain hardware and services are needed, which are listed below. Without any one of these items, connection to the Internet is not possible.
  • Broadband Internet Service (also known as Internet Service Providers or ISP) - Telephone companies (also known as DSL, which uses a telephone line) and cable TV companies usually offer Internet service.
  • Broadband Modem - Normally, a broadband modem can be rented or purchased from the ISP.
  • Computer with a Network Adapter - This is usually a device located inside the computer.
  • Broadband Router - A router is used to connect all of your computers to the network (but is not needed for a single computer). The router also provides a way to connect to the Internet through the Broadband Modem.
Oct 12, 2011 | Dell Inspiron 537 (DDCWQA1_7) PC Desktop
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
All of my test fax are no answer. I have the
Your cable modem is not normally a source for telephone line that the fax machine will support. If you have telephone service through Comcast, You need to contact them about proper hookup to configure your fax line.
Apr 12, 2010 | HP Officejet 6310 All-In-One InkJet...
We re booted the computer and have to use a usb
Not sure what the problem is, but from what i am reading i am suprised that anything worked at all. A modem jack in your computer is for telephone lines, and the cable modem needs a cat 5 network cable as well as a ethernet card attatched to your computer. ethernet card in your computer cat5 cable runs from the card to the cable modem. Magic jack requires a usb connection as well as a broadband connection to work.
Dec 01, 2009 | Acer Computers & Internet
I had been using dial-up internet and then switched over to broadband internat. Now since I have disconnected the broadband net, I want to use the dial-up modem. However, I am gtg a note that the device...
It's kind of difficult to tell what your exact problem may be, but note that the cable and connections for dial-up and broadband are different.
The dial-up cable is telephone wire connected to its port in an internal modem. Broadband is connected with thicker Ethernet cable connected to a network card.
The ports look similar, but the Ethernet port is a bit larger.
So, you need to connect to the right port/card with the right cable.
When you connect to dial-up, you should hear a beep-beep-beep sound from the modem.
Hope this info helps.
Sep 21, 2009 | Computers & Internet
Please tell me what my modem is for a intel insider windows 2000
A modem that is on its own card in a computer is for dialup access to internet, via telephone lines. Other modems that do the same thing are built in to laptop computers, and always have a regular telephone-type plug on gthe computer. Dialup access is notoriously slow compared to Broadband (Cable/DSL) connections.
Sep 15, 2009 | Intel (272757) Modem
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Dell printer A940 fax trouble
Unless you have 'VOIP' telephone service with Comcast, your FAX will connect through your home's telephone line, not the internet (or modem). You would connect your phone line to the all-in-one printer, then follow Dell's instructions for use. Good luck!
Apr 18, 2009 | Dell A940 All-In-One InkJet Printer
Connecting Linksys wrtu54g wireless router with Linksys SPA 2102
If you want to receive "incoming" telephone-calls:
ADSL modem <---> Linksys SPA <---> wrtu54g <---> wired computer
and Linksys SPA <--- telephone-line-1 --> telephone hand-set
and Linksys SPA <--- telephone-line-2 --> FAX machine
or Linksys SPA <-- telephone-line-1 --> mechanical telephone-splitter
with telephone-splitter --> hand-set
with telephone-splitter --> FAX
Mar 19, 2009 | Linksys Wireless-G Broadband Router
My Wireless internet card don't work
i think you are a little confused, your laptop may have a wireless card internally, but you need a wireless broadband or cable router for the wireless adapter to pick up a signal.
A fax modem cannot be wireless and cannot be broadband as you cannot fax using a broadband connection.
Assuming you have a broadband connection you will need a wireless modem/ router or roter connected to a broadband modem, not a standard 56k dialup modem as they aren't wireless or broadband.
Nov 08, 2007 | Toshiba Satellite A60 Notebook
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
356 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
