Question about Magellan Maestro 4040 GPS Receiver
Magellan display battery level critical and shut off.
    President:
  • 1,111 Answers
Hi kcallinnow
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Please Support Our Troops
Posted on Apr 01, 2011
My Acer Laptop battery shuts down completely at 40 - 30
Go to Power Options --> On the plan you are using select change plan settings --> Change advanced power settings --> Scroll down till you reach battery and click the + next to it to expand the settings --> Where it says Critical battery level and Critical battery action (on battery) make sure that the level is at 5% and the action is to hibernate. If it's set to do nothing, it will keep running until it's out of battery and completely shut off. Plugging the AC adapter would give it more power. If that isn't the problem, check your battery's connection and consider replacing the battery.
Nov 03, 2012 | Acer Aspire 5742G
My gps screen says battery level critically low. Screen on top of that says Load error. Load button's bitmap fail. Touch screen will not respond
the following advice pertains to the following magellan gps systems.
Bill
Nov 06, 2010 | Magellan Maestro 4040 GPS Receiver
The battery for my magellan maestro 4040 went dead. Bought a new battery charged it and it still doesnt work. Says battery critically low. what do I do. SQ
see my previous answer to the same question i have answered hundreds of times on here..
http://www.fixya.com/support/t5106611-loose_part_power_input_point_need
bill
Sep 13, 2010 | Magellan Maestro 4040 GPS Receiver
Shuts down almost immediately after starting even on charge mode...in non-charge mode "battery level critically low"
Hi matchmakers0
this is a very common problem with your model gps
Bill
Apr 17, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Nov 09, 2009 | Magellan Maestro 4000 GPS
Battery critically low. Turns off soon after it is turned on plug when plugged. Won't come on if not plugged on.
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Aug 31, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Does not charge
the power port is broken...very common on that magellan and others..i have the ports if you are capable of resoldering it yourself..
Jun 21, 2009 | Magellan Maestro 4040 GPS Receiver
I used this GPS for about an years or so butnow when I plug the Magellan 3140GPSit into the car sigarette lighter I get an messages pop up battery low level and it shuts off. I am able to put in my desired...
most likely the power port is damaged and needs replaced.i repair those magellan gps if you need help. if i cant fix it there isno charge. wmetz@comcast.netto open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Jun 10, 2009 | Magellan Maestro 3140 GPS Devices
Unit comes on but goes off in a few seconds. Sometimes shows the "critically low battery" screen but not all of the time.
most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
May 27, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 4040 GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
