Question about Stack-On Personal Wall Safe
Remove the panel from the faceplate. how? - Stack-On Personal Wall Safe
How to remove the faceplate
Take the side panel off, the "Faceplate" is hooked to the front with plastic Prongs, free them up and pull it off
Nov 14, 2013 | Dell Dimension C521 PC Desktop
Will not turn on without removing faceplate and putting it back in
Try cleaning the contacts behind the face and on the sub panel behind the face with either q-tips and rubbing alcohol or a pencil eraser. If you use a pencil eraser, make sure you brush off the debris.
Jan 22, 2013 | Car Audio & Video
ReMove faceplate
Remove the Outer Case Panel on the side by removing the screws on the back that holds it. Now once one side of the case is removed, look down the front on the metal part of the case. You will probably see the plastic catches or hinges from the face plate, push them in to release them and you can remove the face plate.
Apr 11, 2012 | E-Machines D2046 PC Desktop
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Thanks
Jan 06, 2011 | Kenwood KDC-8021 CD Player
Remove protective film wrap from under water dispenser faceplate
I have this same model and was facing the same issue. I even emailed Whirlpool but that didn't help.
You can remove the faceplate by removing the spill tray and unscrewing the two small screws in the bottom. Be careful not to scratch the finish while removing the screws.
The faceplate is held on by several plastic hooks around all edges. Carefully grip the bottom of the faceplate (I put my thumbs on the inside where the spill tray was and my index finger below the bottom front of the faceplate). Get a good grip by pinching the faceplate and pull down and out to remove the bottom. Then push the faceplate up to unhinge the top.
You can let the faceplate hang by the wires while you remove the plastic. I'd also use a stainless steel cleaner while the faceplate is off to get rid of any fingerprints you may have left behind.
To reinstall, hang the faceplate on the top 3 hooks making sure there is a snug fit. Then pull down on the bottom and push it in. It took me two tries to get it back on.
The plastic is stronger than it looks but you'll still have to go slow and be careful with it. Good luck!
Sep 09, 2009 | Whirlpool Refrigerators
How to change a instrument panels lightbulb ?
Unfortunately you must remove the cluster to gain access to these bulbs. Remove radio, heater fan knobs, temp slider knobs,and temp control faceplate (carefully remove bulb in faceplate), then remove the Phillips screws inside the holes where these came out that hold the cluster . unscrew or unclip and remove the speedo cable from the back of the cluster. you may have to disconnect some electrical jacks (remember where and how they go back in!) to gain complete access. Then it's just a matter of pulling out the little bulbs and replacing them. Because this is so involved I would replace ALL of them at once. Hope this helps...;-)
Apr 09, 2009 | 1993 Volkswagen Golf
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
Removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
The front panel stuck
This head unit comes with a security screw that can be installed to secure the faceplate for retail display. If it was purchased as a demo model, the screw may be in place. To check, the deck has to be dismounted from the vehicle. The screw location will be in the side of the chassis, near the faceplate on the same side as the release button. Removing the screw will allow the faceplate to come off.
Mar 06, 2007 | JVC KD-G401 CD Player
Stack-On Personal Wall Safe Logo
136 people viewed this question
Top Stack-On Home Security Experts
Lawrence Oravetz
Are you a Stack-On Home Security Expert? Answer questions, earn points and help others
