Radio Shack Remote Control
Problem for Radio Shack (15-2146) Remote Control
Menu Button not working, can't record
By cihixon on Aug 02, 2008
I have a RadioShack 6 in 1 remote 15-2146, I have every thing programmed correctly atlest it seems to work. However, when i try to use the MENU button to pre-set a recording time it does not work. I can hit the MENU button but nothing will happen the other buttons seem to freze until i exit out by hitting the menu button again. Other that this the remote is fine, but i would like to be able to record and am not able to do so HELP!!!!!!
Solution #1
posted on Nov 13, 2008
Not Rated)
martinmarty
Rank: Master
Rating: 93%, 11 votes
There must be some keys active after you press Menu. Like you said, it must be waiting for you. After you hit Menu have you tried all the numbers and arrows?
If you can't get any of them to respond (except hitting Menu again to exit the menu) perhaps you need to try a different manufacturer code for your device. For example, if you have Brand ABC Model XYZ, perhaps the valid remote codes are 012, 013, and 014. Even if you have found that 012 works for most things but you can't record, you should try programming the remote to codes 013 and 014 and see what happens. There could be slight differences between the codes that allow most features to work, but not ALL features, just as you are experienceing. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Radio Shack Remote Control
Questions and Unsolved Problems for Radio Shack Remote Control
Do you recommend Radio Shack (15-2146) Remote Control?
Answer
Answer
any1 got code for bush tv got universal remote cant use it
Answer
I need de code for de Phillips DVD and for TV AKAI
Answer
Radio Shack (15-2146) Remote Control programing codes
Answer
I can not get the codes in the manual to work with direct-tv. I have tried all of them nothing... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Remote Controls Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
