Question about Craftsman 2600 PSI Honda Powered Pressure Washer
What does it mean when black smoke comes out of the exhaust?
  • 59 Answers
It is running too rich.
first check the air filter and clean it.
if thats ok then the carburettor has a problem, something like the needle valve failing to do its job or the float height needs ajusting.
try it temporarily without an air filter first to see if thats the prob.
Posted on Mar 16, 2011
Engine emitting black exhaust smoke and lacks power when accelerating
Black smoke means the vehicle is running really rich , do you know what that means ? lacks power when accelerating could be plugged catalytic converter . Fouled spark plugs . Leaking , fuel injectors , fuel pressure regulator leaking .Air filter clogged .Hooking up a scan tool an checking fuel trims , seeing if the computer is taking fuel away or adding .Seeing what the computer is seeing
Why black smoke coming from my car engine Troubleshooting 1 Must Watch
Mar 26, 2017 | Cars & Trucks
Black smoke
Black exhaust smoke means the engine is burning too much fuel. The first think you should check is your air-filter and other intake components like sensors, fuel injectors and the fuel-pressure regulator. Other reasons could be a clogged fuel return line. Black smoke is usually the easiest issue to diagnose and fix, but burning unnecessary fuel will definitely affect your fuel economy, so don't think of avoiding this one to save money, it won't work.
Any smoke coming from your car's exhaust pipe is a sign that your car is in distress. Pay attention to what it needs to ensure more miles for your vehicle.
Jul 07, 2015 | Cars & Trucks
Heavy exhaust smoke coming from tail pipes while sitting still or taking off. What's the problem
Is it black? black smoke means you are burning too much gasoline could be a bad choke or even a dirty air filter.
Blue smoke means you are burning oil out of your engine
.White means water getting into crank case or pistons.
Apr 08, 2015 | BMW X5 Series Cars & Trucks
2000 Kawasaki KLR 650 black smoke comes out the exhaust pipe
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a nice day.
https://www.klr650.net/forums/showthread.php?t=34138
How to fix black smoke from exhaust
Kawasaki KLR650 Service Manual
OEM Parts for Kawasaki
2000 Kawasaki KLR650 Owner Manual
May 22, 2014 | 2000 kawasaki KLR 650
Exhaust smoke at idle speed
What color of smoke?
Black means too rich....adjust idle mixture.
Blueish means oil burning...bad rings, bore or valve guides
Whitish means moisture...condensation...should burn off after several minutes, regardless of throttle setting.
Dec 04, 2013 | Motorcycles
1985 Ford F150 302,5.0 Smoking running Rich and idling high and low
first of all u need to determine what color of smoke it is and is it coming out of the exhaust pipe. black smoke means excessive gas burning ...blue smoke means burning oil ...white smoke if seen in warm weather conditions means coolant leak into cylinder heads... but as running rich and high low idle might have a vacuum leak or carburetor need new base gasket or rebuilt ... good luck
Oct 13, 2013 | Cars & Trucks
Black smoke coming out of exhaust, only on immediate acceleration. Leaves black spots on ground under exhaust pipe.
Your engine is running "too rich" meaning more gas is going into the chamber than is supposed to. If it is a late model, to need to see your mechanic. FYI , blue smoke is oil, black too much gas, white, antifreeze, (really bad).
Oct 10, 2009 | 1987 Jeep Cherokee
Hard starting and to much smoke when engine running idle and sometimes fluctuation
Smoke usually there's a problem.... Bluish gray smoke means you're burning oil (could be a number of things like piston rings, valve seals)... White smoke means could mean you're burning transmission fluid, or there's a crack in the gasket or engine block.... Black smoke could mean you need your air filter changed, bad fuel injectors, bad distributor cap, ignition coil... I would guess it's probably black smoke coming out of your exhaust from the sounds of your symptoms...
Aug 11, 2009 | 1993 Saturn SL1
Kia sedona 2.9 diesel black smoke exhaust
Black smoke from exhaust means engine getting to much gas.
May 23, 2009 | 2002 Kia Sedona
Black smoke from exhuast
black smoke from exhaust means a rich oil/fuel ratio, sometimes it causes by a clogged air filter or a problem on fuel injection system.
Jun 23, 2008 | 1990 Nissan Stanza
Craftsman 2600 PSI  Honda Powered Pressure Washer Logo
278 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
