Question about Vacuums
Hello. WE have a volta Vacuum Cleaner U4005 . Type VC-T4005ES-ES-2It is the two speed/variable speed model. On startup, it "Starts" in slow speed& after a couple of seconds goes into "Run" or full speed. The start speed has faled. I am looking for a schematic wiring diagram. an you help Please. Regards. Johndeejay
reddevil6
  • 1673 Answers
SOURCE: repair manual for Eureka 4335 Type D upright vacuum cleaner
Maybe these pictures will help:
Posted on Feb 17, 2008
  • 73 Answers
SOURCE: Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Posted on Aug 27, 2009
  • 114 Answers
SOURCE: Rainbow Vacuum Cleaner starts slow smells hot
I would suggest that your motor bearings are packing up. You will eventually harm the windings by overheating (although there is a thermal limiter). The bearing replacement is a job for a service shop unless you are pretty handy.
Posted on Dec 20, 2009
SOURCE: Miele s571 vacuum cleaner power surges up and down
I just repaired the same problem. It is not the motor. There is a defective capacitor in the regulator. Large grey capacitor should have a value of 0.22uF/275V. It was in my case just 85uF. Changed capaitor and it was OK.
Posted on Feb 08, 2010
  • 3 Answers
SOURCE: we have a zenith dehumidifier
I've had the same issue with mine. I am a 12 year refrigeration tech. I checked the float switch which would normally cause that indication light. However manually pushing the switch and then checking it with an electric meter that was not the case. I think that is instead, an error code set by the manufacturer to assist the service tech when or if this failure occurs during the warrenty period. I also checked the next possible failure in the sequence of opperation which would be the compressor overload relay. That is sometimes why, as some people have posted, that after when unplugging the unit, it operates for a short time then again fails. In my case that was the failure. If that would have not been it than I would have tried the compressor start relay. I purchased the overload relay from my local HVAC/plumbing supply for around 7$. The control can easily be replaced by any handy homeowner. Also, as a service tech, 7$ and two wire nuts is better than a 145+$ service call.
Posted on Mar 20, 2011
Shark NV350NZ NEED 2Filters 1 foam 1 falt and pipe on rotating head were I get them and price please
Shark Vacuum Parts & Accessories ' eBay
www.ebay.com/sch/Shark-Vacuum-Parts-Accessories/42146/bn_7722312/i.html
  1. Cached
Shark Professional Rotator Lift Away UV560 Floor Nozzle Part NV501 HEAD ... Shark NV400 Rotator Rocket Vacuum Cleaner Motorized Floor Nozzle lower ...
You can obtain parts from the above. Quote model number.
May 24, 2016 | Shark Vacuums
Dw621 pulsing speed problem
Try to start it at various speeds. Use contact cleaner on the switch, and the variable speed control resistor.
Mar 02, 2014 | Dewalt DW621 2 HP Evs Plunge Router W/...
Miele canister keeps shutting off when i press + it starts again for short while and off again whats problem i have changed bar but still no good
Was it hot when you pressed "+" button? Did you check the filters(Hepa) or bag if clogged or suction path was blocked? Does it happen after it was cool down? From what you said, it seems none of the above. Only thing I can think of is circuit board. The mortor runs in variable speed. "+" increase the average voltage to the motor thus higher suction. PWM circuit in main pcb may not working correctly.
High priced vacuum cleaner like this shouldn't fail like this but it does. JMO.
Nov 07, 2010 | Miele S548 Bagged Canister Vacuum
I have a volta ultima vacuum and the brush won't turn around anymore.
Tip the cleaner up and were the brush is theres a belt it is either slipping or broken replace. Undo cover over brush and undo brush lift out put new belt onto motor and then the brush and reassemble
May 17, 2010 | Vacuums
A BELT FOR THE VACCUM CLEANER (EUREKA)
Here's a link to this exact belt for your vacuum cleaner on our website:
http://www.govacuum.com/1555.html
I hope this information helped you! Please be sure to rate this helpful if it did so other Fixya users with this vacuum can easily find this belt.
Thanks,
Chris J.
GoVacuum.com
Mar 30, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
Apr 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
It does not ****
Greetings from GoVacuum.com,
It sounds like you have a clog in the vacuum cleaner somewhere. What you can do is remove the hose from the back of the vacuum cleaner and see if the changes the bag full indicator, and pay attention to the sound of the motor. If the motor starts making a high pitch sound as soon as your install the hose, this means that there is a clog somewhere in the hose.
If you can give me your model number, I can send you a parts schematic to your vacuum cleaner.
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum cleaner smells bad
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=732502
Generic problem for all Vacuums
Posted by WhyAge on Jul 02, 2008
My Vacuum cleaner smells bad. What can I do to stop that?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Depending on the brand name and model # you should do a few things, try changing the bag and or change or clean the filter depending on what type of vacuum you have, a dirt cup model or a bag system. The vacuum cleaner dealers have Vacuum crystals that can be sprinkled down on the carpet and then you can pup the crystals from the carpet with your vacuum. If not I suggest that you take it in for a good and general cleaning – a lot of times the dirt and dust get built up under the hood and just sits there – especially if you have pets and it is a hard smell to get rid of unless you have it serviced or cleaned. If you have any questions, please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Vacuums
Miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Mar 05, 2008 | Vacuums
Vacuums Logo
85 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
