Question about Excalibur Kingmaster Lll Electronic Chess/Checkers
After the 4th or 5th hint the screen shows a gray bar across the screen
2010 crf450r jumping outta gear from 5th to 4th all other gears work fine
Terrence >>>> 1. Do not go through the gears while idling on a stand!!!
The rear tire is not moving at the speed that is normal for 4th or 5th gear..AND if you do get the tire moving that fast.. it is BEYOND DANGEROUS!!
This sounds like the 4th and 5th gears may need replacing.. or the shift drum detent for 5th gear has somehow become ineffective.. If you continue to ride this bike , you may cause more trouble and damage to the transmission.
Take this to a qualified professional!!
Jun 24, 2017 | Honda Garden
How can I get into my ipod if I forgot my pass code?
you might have to reset it to factory settings
The 4th generation iPod is a portable media device that can play music, videos, and display photos.
Occasionally, you may run into issues with the iPod where the player has trouble working.
Restoring your iPod to its factory settings will often correct any software issues the player may have by wiping all of the data off of the iPod, and restoring its software to its original condition.
Restoring your 4th generation iPod can be done in just a few minutes, and requires the help of your computer.
Connect your iPod to your computer using the included USB cable, just as if you were going to sync it to add music or other data.
Launch iTunes if it does not launch automatically, and select your 4th generation iPod from the list of devices on the left side of the screen.
This will launch information about your iPod in the main iTunes window.
Click the "Restore" button in the middle of the iTunes window to begin restoring your 4th generation iPod to its factory settings.
Your computer may ask you to enter an administrative username and password to continue. A progress bar will then appear letting you know the status of the restore.
Wait for the progress bar on the screen to finish and then disconnect your 4th generation iPod.
The iPod is now restored to its factory settings.
You can reattach the iPod to your computer and set it up again, just as you did the first time you used it.
hope this helps
also you could try This works on iPod 5th gen
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
Oct 17, 2012 | Apple iPod 4th Generation MP3 Player
What different gear box can fit honda integra xsi vtec 1600cc b16a? i want to change my gear box ,and i want to know what exactly other gear box can fit my car?thanks its a integra bot the product can show...
J1/S1 Found in: Integra XSI/RSI (DA6) Type: Cable 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400 Y1 Found in: CRX/Civic (optional LSD) Type: Cable 1st: 3.166 2nd: 2.052 3rd: 1.416 4th: 1.103 5th: 0.870 R: 3.000 FD: 4.266 YS1 Found in: Integra 92-93 XSI/RSI (DA6, DA9) Type: Cable 1st: 3.307 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.880 R: 3.000 FD: 4.400 S80 Found in: Integra Type R 98+ (LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.785 S80/Y80 Found in: JDM SiR-G (optional LSD) Type: Hydraulic 1st: 3.230 2nd: 1.900 3rd: 1.360 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.400 Y21/Y80/S80/S4C Found in: JDM 96-97 Integra R(LSD) JDM Civic R [EK9](LSD) JDM Civic SiR [EK4, EG6] JDM CR-X DEL SOL SIR (EG2)(optional LSD) USDM DEL SOL VTEC (EG2)(OPTIONAL LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400
Jun 08, 2009 | 1990 Honda CRX
The lcd screen is gray with black bars across it in every mode.
Could be you ccd, charged coupling device, eye of camera. May be pricey to repair. go to panasonic on line for quote
Apr 15, 2009 | Panasonic PV-GS31 Mini DV Digital...
Puzzle 100 in professor layton
This took me ages. Hope it not too hard to follow.
1st square is a small one made up of the top left four pins of the 1st and 2nd row,and is the only straight square on the board.
2nd square is made from 3rd pin top row connected to 5th pin 2nd row, then make a sq from here.
3rd square is made by connecting 4th pin top row to 3rd pin down on far right row, then make the largest sq from here.
4th square is made by connecting 5th pin top row to top pin in the far right row then make the sq from here.
5th square is made by connecting 3rd pin 2nd row to 2nd pin down far right row, then make the rest of the square from here.
6th square is made by connecting 3rd pin across on 3rd row to 4th pin across on 4th row, then make the rest of the square from here. Finally 7th square is made by connecting 1st pin 4th row to 1st pin 5th row, and make the rest of the square from here.
When I describe pins, I am talking about actual pins, not counting gaps where pin could be.
Hope this helps.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Gray Bars
Yes, I also have the same problem...
Apr 25, 2008 | Sony Handycam DCR-HC36 Mini DV Digital...
Gray bars across the screen...
try to clean the video head using a blank new tape just forward it 5 times as need...do not use video cassette cleaner cause it too rough for the head....check the head if there no crack on it....if nothing you find it is time to replace the to the service center...
Jul 27, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Excalibur Kingmaster Lll Electronic Chess/Checkers Logo
94 people viewed this question
Top Excalibur Games Experts
Lesley Cameron
Lesley Cameron
Pamela Leach
Pamela Leach
Are you an Excalibur Game Expert? Answer questions, earn points and help others
