Question about Husqvarna Garden
I have a 141 that starts fine when cold, but after it runs a while it is hard to start back up again. What is the trick to getting it started again after I shut it off.
    Sergeant:
    Champion:
  • 250 Answers
First make sure the air filter is clean and if it is try holding the trigger half way open and make sure the clutch brake is on.
Posted on Mar 16, 2011
I HAVE A 2001 CHEVROLET BLAZER THAT STARTS HARD ON COLD MORNINGS. NO RED LIGHTS OR CODES BEING SHOWN. TUNE UP RECENTLY COMPLETED (PLUGS, WIRES, CAP ROTOR). ONCE STARTED BLAZER RUNS FINE AND STARTS FINE...
SOUNDS LIKE ITS GOING TO NEED A NEW FUEL PUMP THE FUEL IS DRAINING BACK INTO THE TANK AND IT HAS TO BUILD UP FUEL PRESSURE AGAIN BEFORE IT WILL START
Nov 04, 2013 | Cars & Trucks
1990 Volkswagon Jetta won't turn back on after long drive.
Then you have a start up problem and it reside with the cold start valve,The cold start valve operates even if the vehicle is warmed up,the cold start valve can be plugged up,or even have a bad connection,The cold start valve operates by a thermotime switch.This switch located on the near bottom of the radiator may have gone bad or disconnected,Here is the easy cost effective route, replace them both,it will cost more to trouble shoot it than just replace it.
Aug 07, 2012 | 1990 Volkswagen Jetta
Jeep will not start back up after it get heat in the block
the crank posistion sensor is bad replace it and that should do the trick prety big job
May 07, 2012 | Jeep Cherokee Cars & Trucks
I have trouble starting my 2007 HHR upon initial start-up. it sputters but after a few seconds of that it starts to run fine. I can stop somewhere turn it off and crank it again and it starts fine seems...
this could be a bad fuel pump that has a problem from sitting over night or when it cools down enough.the armature in the pump may be worn and when its cold it has a hard time turning the pump because of it being worn and when it gets warmed up enough the clearance is closer than when cold and works fine.
Sep 08, 2011 | Chevrolet HHR Cars & Trucks
I have homelite UT10560 chain saw. The problem I have is it will start and run when cold. But if the saw shuts off it is very hard to start again. What is the trick to start when saw has been runing...
Make sure you have control set on run,not choke or start. Check spark aresstor by removing exhaust cover and cleaning screen of carbon and oil build up with spray carburater cleaner and fine wire brush.Also remove gas cap and make sure that vent hole in cap is open.Otherwise it can draw a vacumn after being ran for awile and be very hard to start.One last thing is make sure that spark plug gap is correct and that there are no hairline cracks in porcelin insulation. Best of luck. Thank you.
Apr 20, 2011 | Homelite ZR10926 16" Chain Saw
Starts fine cold then starts and shuts off then starts very hard but will start . could this be fuel pressure regulator what what happens to make for lean air fuel mix during cold start in 80's had a cold...
The computer runs the fuel mixture rich when cold and then leans out as it warms up into closed loop, a common problem is the regulator leaking, if you remove the upper part of the intake and then turn key on and watch for fuel leaks, another trick is to remove the throtlebody and use a light to see if fuel is puddling up on the top of the intake, make sure to dissconnect module connectors to avoid a false start or spark that will cause a fire, i would almost bet its the regulator, hope this helps,
Dec 07, 2010 | 1997 GMC Sonoma
Hard to start by sub zero temp
oh oh oh, thats why father christmas uses a horse,,,
dieal engines dont get very good starting when its realy cold,,,
the heater light may go out but are they getting realy hot???? if not it wont start very well, my trick is give it twice the heat turn the kye to pre heat when the light go's out very quikly turn it off and back to pre heat again,,, when you have dont this the second time start her up,,,
now watch her go??? the heater relay should hold the heaters on for a minuet or so even though the light has gone out, so your could be fulty and it turning them off to soon, and a biseal with out heat is a dead duck if its cold,,,do as i all ways do if its cold,,,,twice the heat then start her up, it takes far less out of the battery that cranking up twice
Oct 24, 2009 | 2004 Hyundai Santa Fe
1983 300td hard to start when cold.
The glow plugs can be worn also.Make sure the glow indicater is nice and red.
Aug 30, 2009 | 1983 Mercedes-Benz 300-Class
Runs bad til put foot in it
it could be blead back on the fuel line it may draw air while it's setting over night then you start it fuel pumps up and its fine till you let it set overnight again allowing it to again draw air in the fuel line
Jun 22, 2009 | 1991 Honda Accord
Garden Logo
51 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
