Question about Toshiba Computers & Internet
Need to download Toshiba RAID/SATA driver package for Windows XP MCE 2005 installation.
    Novelist:
  • 202 Answers
Go to www.google.com put Toshiba RAID/SATA driver package for Windows XP MCE 2005 u get a link select and download or else try from www.Toshiba.com website or else from www.driverguide.com
Posted on Aug 02, 2008
I am cannot install OS Xp on laptop blue Il1,because drivers not support
Actually the problem is that the sata raid drivers of the IL1 is not readily available on the windows XP installer package. Another problem is that you cannot use the drivers on the installation because it uses a disk drive for loading and the IL1 have no disk drive or CDROM with it.
The solution is download or get the sata raid driver for the IL1 placed it on a diskette and attached an external CDROM and an external disk drive on your IL1. Open your notebook place the Windows XP CD in the CDROM, place the sata raid driver diskette on the disk drive. Make sure that the booting priority is set to the usb CDROM.
Upon loading of the Windows XP installation, you will notice a message on the status bar below the screen asking you to press F6 if you want to add additional device, press F6 and follow the instruction on adding the sata raid driver. Then your installation will continue till it finishes the Windows XP installation.
There is another way, but a little complicated. It is making a flashdrive installer of Windows XP OS. an integrating the sata raid driver in the flashdrive Windows XP OS installer. there's a guide somewhere in the internet that discuss the process step by step, I just can't remember on what site. I fount it by searching the net, I'm sure you can find it if you have time.
For now that's all I can share. Good luck friend.
Dec 14, 2010 | CTL IL1 Notebook
Why the windows xp cannot be loaded for laptops.They are asking for raid drivers.Then how to collect the raid drivers,and how to load the window xp for laptops.I there windows xp available with raid...
Here is what you need to do to install XP on your laptop that came with Vista or Win 7.
If your hard drive is SATA (pretty much standard these days) you will need to search the manufacturer's site for a floppy disk SATA driver install package.* You will need a USB floppy drive for installing XP.
* Copy the SATA drivers (should be denoted as "F6 drivers" or similar) to a blank disk.
* Have the USB drive connected. It should automatically map as A:\.
* Go into BIOS and find a setting for ACPI Compatible and set on.
* Now install XP normally from the CDROM, and when it says "press F6 to install third-party drivers", press F6 and follow the options to get the SATA drivers from the disk.
* Complete setup as normal.
or
You can check the following link for more detailed info.
Thanks !!
Please rate the solution if it helps you.
Nov 23, 2010 | Computers & Internet
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
Not Changeing sata to ata
You will need to go into the BIOS and disable SATA RAID. then windows XP setup will show the HDD.
Jul 02, 2009 | Microsoft Windows XP Professional With...
I can not install windows XP on Toshiba Satellite U300, windows
You must have latest Windows Xp CD .
Latest Motherboard chipset does not recognise hard disk without proper sata raid or sata driver. So you can install sata driver if u have USB floppy drive by downloading latest Sata raid to floppy. At the time of installation you will see a message press f6 to if u need to install raid driver.then press f6 asking for floppy drive and floppy insert press enter to continue.
Jun 27, 2009 | Microsoft Windows XP Professional With...
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Installing WIN XP SP2 in aToshiba Satellite A205-S7459 Vista original
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
simple solution: get WINDOWS XP CD with SP3 it contains support for sata drives
Workable Solution:
this specific model of Toshiba was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
SATA DRIVER FROM:
http://downloadcenter.intel.com/license_agr.aspx?url=/17268/eng/iata87enu.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17268&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
after windows XP installation u will have one more task to find drivers for ur notebooks with XP support but it is the next step if ur some hardware like modem / sound/ doesnt work then i can help more
pls let me know if i can help u more
and rate me FIXYA if i have fixed ur problem
Mar 03, 2009 | Computers & Internet
Installation of windows xp on a preloaded windows vista laptop
See this , you have to download the SATA driver , as you have a SATA hard disk , then slipstream it into the xp installation package.
Alternatively , put the driver on a floppy and press F2 when prompted during the setup when its loading all the files (It says Press F2 if you want t o install a SATA Driver"
Then it will detect your drive and install as normal :D
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Jan 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
XP Media Centre Edition 2005 drivers
Ususally the vga or graphics drivers,lan drivers,chipset and audio drivers are enough. If you are using more than one harddrives in raid 0 or raid 1 then you will have to install the raid drivers too.
Sep 23, 2008 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Thomas
It should be on the driver cd that came with your main board,, If you need it to install windows, there is a readme file in the SATA/Raid Folder which contain the instruction for putting it on a floppy disc, basically it involves copying the .sys , inf files to the floppy,, The folder to be copied is named floppy
If you dont have the cd consider using Vista or MCE these have sata drivers built into them
Jul 12, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
226 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
